Spreading the Bonney affliction!
HeelSpur
WV
The Bonney Jackrabbit Wrench is described on p67 of the 1914 catalog as having openings for each of the eight principle nuts used on farm machinery. Made of malleable iron.
Edit - Aw heck Twertsy, you beat me by five minutes!
Been trying that catalog but all pages are blank on my end, except for the front page.
HeelSpur
WV
Huh, try downloading it and then opening it. I have the same issue at the office sometimes.
I switched over to Chrome and got it uploaded in a split second.
mv213
Dallas, OR (the OTHER "Big D")
Here are a few Bonney sets i have
8 point wrench and a starter wrench
Hi Bob15, sorry to reply to such an old post but I found an 8-point Bonney like the one in your picture in an old car I'm cleaning out to sell for a family member. I have seen old square-head lag bolts, but is that what this wrench was made for, or something else.
Thanks for any knowledge you can share!
jp
LesserSon
PA USA
The D2857 (double-square openings) and 2857 (single-square openings, at least until it was discontinued) wrenches were made to adjust early Ford brakes. They were offered first in select steel, then CV steel, Zenel steel, and finally Bonaloy steel. I have one in CV, and a comparable #6000 wrench made by LectroLite.
mv213
Good to know, thank you. Not sure what I willl do with it, don't have any early Fords!
LesserSon
PA USA
Ran across these three pairs of 401-series tappet wrenches in a small shop today, and they followed me home. Date codes 1926 & 1927.
BlueBomber
Outside Boston, MA
I posted this single offset Bonney Zenel Z2830 on the DBE thread, but am also putting pics here for completeness:
c67671f7afa8a3e09b5a50c4f32bcb73.jpgd29ca682995d39794d83e6822d16a04f.jpg951464cd93599bd73821d18aebe4d04e.jpgc90415ba93cda28f0b95b8cd39365ab9.jpg
Mikeske
Washington State
I thought I lost the 1/4" Bonney ratchet V-702K and today I digging around my other garage and I found it. Now I have the complete set of 1/4". 3/8", and 1/2" Plus I have a gold flex head 3/8" that is not pictured. I was digging around the other garage for something else I put in a cabinet and this pops up. I have never seen any having the 1/4" ratchet either on eBay or anywhere else.
LesserSon
PA USA
Posted on Twertsy's Ratchet Collection Thread, and now here:
Traveling through Lewisburg PA, I stopped in a "Street of Shops." Tools were few among the hundreds of stalls, but I spotted this partial set (some of the sockets are filled in from other mfgs) of Bethlehem Spark Co ratchet/sockets made by Bonney. Traces of the copper plating remained. The box was wood with most of the hinged lid missing. Marked $45 - well above my idea of its value.
Mikeske
Washington State
I went to couple pawn shops in the area today, finally found a pawn shop that a rather large collection of tools, Found this old Bonney wrench W1164 a 5/16ths wrench. Cost $1.00
snapmom
Florida
Bonney AT-8010 Packard Merlin Rolls Royce tool kit wrench.
bonneyman
Desert SW
A triple play of Bonney. What a sight!:thumbup:
Notice the tri-wing selector knob on the 1/4" vs the single ridge of the larger two? I believe the tri-wing design is original, started in 1967. The single ridge was on-line by 1981 and stayed until Bonney ceased production in 1994.
Exactly when the switch occurred I don't know. I want to say I saw a 1977 catalog and those rats were still tri-wing.
bonneyman
Desert SW
Now all you need Mike is a Bonney 3/8" drive in a 1/4" body! :lol_hitti
Mikeske
Washington State
I bought the entire set in 1982 and the V-702K might have been a left over from the earlier years. I always wondered why the 1/4" had the Tri-wing design and the others did not. What I think happened is the single ridge was done first to the 1/2" and 3/8" and they finally did the 1/4". I did take it apart and greased the moving parts and the ratchet is almost as smooth as my 80 tooth Snap-On. I actually like to use the Snap-On if clearance is not a issue as it is has a longer handle, if I run into a clearance issue it is the Bonney as it has a shorter handle. Edit: I have added a picture of my gold flex head 3/8ths that I acquired from eBay. I had a standard flex head 3/8ths that a five finger mechanic took out of my toolbox years ago.
twertsy
Reedville, VA
Here's mine, with the 3/4.
LesserSon
PA USA
Picked up five Bonney Shield wrenches today at a neighborhood yard sale. The seller had quite a hoard of various old USA tools and masses of unsorted fasteners. Among these, a Ford reverse gear, and a small DOE having an unfinished gullet.
Anyone know what the CV 9268 single-open-end obstruction wrench is for? The other side has another number 43525. The date code is either DO or DQ, so mid 1920s. I haven't spotted it in any of the catalogs.
LesserSon
PA USA
And some new stuff today: a big old WP4 phillips screwdriver missing the ferule (I probably have one that will fit. Jason, are you still gathering these?), an A704 ratchet in working order, a TuHex DBE, a Zenel 3034A DOE, a CV drive stud remover, and two 1st generation Bonaloy combo wrenches. There were several sizes of these, mostly marked with the initials REO, but of the ones available, I already had examples of all but these two.
Remarkably, there's a WP4 screwdriver on eBay (with paint and ferrule) not far from my location: https://www.ebay.com/itm/132280079808
wvrailroader
West Virginia
Found this 32 oz brass hammer at the local flea market for $2. Couldn't pass it up.8d39eeaddd8e1451408fdfa54fdcc699.jpg
Sent from my SM-G930R4 using Tapatalk
bonneyman
Desert SW
Dang, that little putter has been used to death! Prolly down to about 16 oz if you grind it and clean it up right. :lol_hitti
Sam'sAutoParts
Northeast PA
Very nice find on the hammer.
After several years I have come to terms with the fact that brass hammers are not a common item in my neck of the woods. Almost wonder if they didn't get scrapped when brass was high. I still keep an eye open for one, just in case.
dutchgray
Dorset. England.
I have never seen a used brass hammer for sale anywhere locally. I think very few people buy them new.
DadsTools
Have a question for all you Bonney fans. I have a Bonney combination wrench set I'm thinking of selling. 11xx series, longer than standard length, looks like what you'd call a full polish, 3/8" to 1". It's missing the 1/2" and 11/16" sizes. I do have some wrenches I could substitute from Williams Superrench, Proto, or Armstrong, but not all the same--each of the two subs would be different from each other.
Here's the question: do I put in the substitutes to complete the set or sell it as all Bonney without the missing sizes? And if subs, which would you prefer, Proto, Williams or Armstrong? :dunno:
Sam'sAutoParts
Northeast PA
May want to check HJE, they have a few Bonney wrenches on closeout. It may be worth while to fill out the set, even if you end up with a one or two satin finish wrenches.
Is your set 12 point loc-rite?
LesserSon
PA USA
DadsTools, I think if a person needs a full set of USA wrenches, and doesn't care if they are all Bonney, then they probably don't care if there are any Bonney.
I think just sell what you have. A full set will command a premium over a broken one, but sourcing the missing ones will cost time and money, eating up that premium.
Mikeske
Washington State
Does the set look like this. If they are. they are the full polish set longs. I do not need your set as I also missing the 1/2" long, but I am just posting this so you have a idea
Mikeske
Washington State
Oh....that is some nice tool **** Mikeske
Thank You those are my original set of wrenches that I bought in 1982. Someplace I also have a full set of metrics that I have not yet located but I still have another garage that I have not yet finished cleaning out. I used those wrenches daily as a aviation mechanic until I retired earlier this year.
Jp267
New England
I bought a box of various Bonney sockets and wrenches from a guy last summer. There were also Proto and New Britain in the box. He had it listed on Craigslist for piece by piece with a cost for each individual socket etc.
I told him I'd give him $50 for all of them and he agreed. There were probably 150 sockets and 75 wrenches including a bunch of old 1in plus box wrenches.
Great to see Bonney here. Really like using them.
larry_g
oregon
I picked up a Bonney usa 2810 double box wrench, deep offset, 1"x 15/16" 12pt the other day. I was looking for a 1" box 6 point to cut up and make a tool post wrench for the lathe with.
So before I cut this up for my use is there anyone willing to trade a 1" 6pt , good brand, deep offset, for this one? This is engraved and a couple of stains from rust. Just offering to the group if it is something special or needed to complete a collection or set.
If so PM me
lg
no neat sig line
Username already in use
Always happy to add some more Bonney to the collection.
1/2" drive ratchet
13MM Loc-Rite
1/4" drive socket
1/2" drive CV socket (6pt)
Mikeske
Washington State
Well went out and hit a 2nd hand store and found a 7/8ths Bonney tubing wrench and a Herbrand 11/16ths and 13/16ths deep well sockets. Yeah I know Herbrand is not Bonney but they have the triangle on them so I posted a picture of them.
