Thanks!from my experience just ok for home use, the mechanics at work hate them, they prefer Knipex or the all steel Hazet. I personally like the Knipex and the Garant ones more
Sent from my SM-A510F using Tapatalk
The ones I have seen in UK were made in Germany, if I recall correctly.Metabo jigsaw earning its keep, the tube I was cutting a radius out of was 5mm wall..
Sadly it carries only the name from the old world.. it's Asian made
news from Festool:
"Hybrid" sanders.....corded/cordless:
Well ****, there goes the wallet.
Hi, two vintage socket set
Two mini toys!
Stahlwille mini set.
Unior mini set.
[emoji106]
wow crazy stuff. I thought there is more high tech involved like huge hydraulic cylinders or something like that...made in china huh ?
No hybrid drills, jig saws and Crircular saws[emoji13]news from Festool:
Do they offer shop tours ?Hi Monte,
These are only the legs of the platform as part of the system.
The plates arrived from Germany to China where they are flame cut and prepared. These shops are specialized in this kind of fabrication and they have latest machines mostly from Europe, Germany and Swiss.
Afterwards they are sent to the shipyard where they are welded on top of each other, Longitudinaly, in order to form the full length/ height, in this project about 200 meters[emoji16] .
The gear boxes and electric motors are installed and the big slow turning pinions are engaged on these teeth. Through some automation and software the gears move the whole platform up and down as required in order to start the drilling!
(and obviously some people). I guess the angle grinder was used for deburring ? And i guess it takes a while until the platform earns its costs back at this dimensions of the platform...Who knows.... maybe the sanders are just the beginning..... ?No hybrid drills, jig saws and Crircular saws[emoji13]
piiiics....Found a Dowidat 46/50 mm wrench for $3 suckers huge and as of now will look great hanging on my wall as I have no use for something this large. It's under the car seat right now for personal defense haha.
nice pictures ! (and tools)
...and USHKraftgrip, from the same factory as Gedore, Unior, Hazet and SK Tools screwdrivers.
...and USH
Oplast right?
Is oplast somehow related to UNIOR?Yes.
As far as I know oplast is OEM for Unior...Is oplast somehow related to UNIOR?
If not how would you compare these two in terms of quality and fitment of the driver tip?
Thanks!
...and handles for Knipex pliers. I was there, I saw it.
Ex-army Tool roll by K Garrett, on FlickrI guess their screwdrivers are from there too ?
Thanks!
The max width is about 71mm. There is a slight play in the chuck. No percussion version available. But with a good sharp (Bosch Multiconstruction, Alpen Profi Multicut) etc.) drill bit you can easily drill into stone without a percussion mode. And for concrete rotary hammer anyway. The maximum torque is measured basically with the drill at full speed driving a screw into a block of steel. I dunno if this says much...Hi Monte,
Maybe you could provide some info about the Fwin ASCM which seems very similar to the Festool PDC 18/4?
Is the fein of similar width of 60 mm to 65 mm?
And how is the woble of the quick chuck?
I also forgot to say tjat the Festool has a percussion mode and the max torque is 60Nm compared to 90Nm of the Fein.
Link for that pruner ?
I have the Fiskars(coo was Finland/US, but who knows now) version which rocks. Just in case i need a new one..
seems they changed the design again. "3D" forging around the sides of the cutting head. Looks nice. And nice pictures too !Two new pairs of pliers from NWS. Got the bigger ones dirty already yesterday. I love how sharp they are.
Or...maybe same blade supplier or made on same machines... ?Could be, they make insulated screwdrivers as well. You could figure that out by comparing the tips of Knipex screwdrivers with the tips of Kraftgrip insulated ones.
or vice versaThey look very similar to "Made in Germany INBUS® - Das Original seit 1934" allen keys, almost too similar to be just similar. Maybe all German hand tools are secretly made here in Slovenia, except for Wera which is made in Czech Republic.![]()
Or...maybe same blade supplier or made on same machines... ?![]()
You can see that Gedore and Kraftgrip are from the same factory if you compare the tips.
Thanks for the link and an excellent comparative review Monte.
It is really a nice "tool" to have.
I´m buying PB Swiss nowJust so you will know where your German screwdrivers are made.![]()
and most likely an oil change.
