Help with a craftsman ratchet
jpickar
I bought a Craftsman ratchet. The new 3/8" pearhead USA made 44808.
I took it apart and cleaned it up. It was real dirty.
Anyway I was putting it back together and the selector retaining ball went......ping....... gone! Yup I lost it for good.
Does anyone know the diameter of that little ball so I can get a replacement from somewhere??
Thanks, John
snapmom
Florida
ck the diameter of the hole. or put the spring in the hole and find a ball that just fits in the hole.
LB-1911
Northwestern Il.
Thanks, John
:see: 2nd page lower right has size info.
Here's the most up to date Craftsman Ratchet Repair Kit Cross Reference/Match-Up Guide for anybody interested. Enjoy!
:deathmeta
Cross reference pdf @
https://www.garagejournal.com/forum/showpost.php?p=5507840&postcount=1
Ball Size
32763 3/32” - 44807 11010
43424 3/32” - 44807, 44812 11010
43427 3/32” - 43186 11010
43427 3.5mm - 43175, 43185 11024
32764 3.5mm - 44808, 44811, 44815, 44833, 44834, 44835,
44836 11024
43434 3.5mm - 44808, 44811, 44813, 44815, 44833, 44834,
44835, 44836, 44837 11024
43437 3.5mm - 43784 11024
51064 3.5mm - 43785 11024
32765 4.5mm - 44809, 44816 11032
43444 4.5mm - 44809, 44814, 44816, 44838 11032
J
jpickar
Ball Size
44836 11024
Thank you for the info and much more!! Now I know where to go!
John
cherrybomb
Near Madison Wi.
I would go to Sears ,p.u. a rebuild kit for a quick fix or call a bike shop for a 3.5 m.m.as a previous poster stated.Or I have two left hands,I would get two 3.5 at the bike shop,if you know what I mean.
JohnDeere1
Kentucky
Next time take it apart or put it together inside a big zip lock bag, I may have an extra ball you can have .
JohnDeere1
Kentucky
I has happened to me too many times the springs as well try finding a paw spring for a 1/4 dual80 in carpet I've usually been lucky and alway find them. Just lost the alignment pin into oblivion for my MG725 air impact in my living room and still no luck finding it so made one out of a drill bit just cut to fit.
Westly
U.S.A.
Thanks, John
I had the same thing happen with a 43785 and the ball was a 1/8", a standard hardware store item. Was 17 cents. They're over in the drawers with the nuts and bolts...
J
jpickar
Thanks for that info. I have since found the ball bearing, but I will be buying a couple of them for the next such episode.
