AdrianBoomer
Thanks dude. I might try this. I post what I come up with.
Wondering if anyone has built any type of dust collection for these sanders?
Doesn't the table go to the belt sander part?
This is the one I have. It is much later and doesn't appear to be as solid as the King Seeley stuff. The table is just cast aluminum. The tracking is fussy and the 3/4 horse motor often needs a push to get it started. Your stand is different than mine My sheet metal table acually flexed so I bolted some angle iron underneath but it is not great. I had bearing noise on the tension adjust end and finally figured out that the press fit bearings were spinning in the casting. Sears was over the hill by then. I also have a King Seeley jointer on a single pedestal that is not on the same planet as that sander. I will keep my eyes open fo a K S belt sander. Mine has no rubber on the rollers. I worked with a Delta sander that has a much better tracking system. The entire idler end tensioned as a single unit with one knob and then one side of the roller adjusted tracking. That is how my band saw does it.Haven't done anything to mine ,except use it since I acquired it in a trade in 1990. Great machine.
I just checked mine and the motor on it is a Ward Kraft 1750 1/3HP. It bogs down on me so maybe I too need to move up to a 3450. I have never looked at a manual and I do like this little motor but maybe the faster RPMs will improve performance, No??
MacGee, can you post a detailed pic of the King Seeley decal on yours? Mine was partially erased.
I would just search belt disc sander, and watch for parts. Did find this aftermarket, but pricey. http://usaknifemaker.com/disc-beveled-9-aluminum-t-6061-5-8-bore-for-disc-grinders-beve.html
Macgee, I will look when I get home this evening. I may have what you're looking for.
Nine, didn't I pick one of these up when we first went to that sale at Barry's? Was thinking I'd use it for a project but then that Delta popped up.
MercLSU,
That would be awesome, please let me know. I've been at it all morning, dismantling, cleaning, scrubbing at the parts. I think it's going to come out really nice, the bearings are good and nothing is damaged or missing.
Womp womp womp...looks like I was wrong; my apologies.
Looks like it's a CM lathe face plate and not part of a disc sander. The hole is ~11/16" in diameter, threaded, and thus isn't keyed or machined for a set screw.
That looks like mine with the ribbed aluminum table. I bought the whole setup as a single item on the Craftsman stand. The table is so flimsy that I had to brace the underside to control belt tension. The 3/4 hp motor is anemic. There was no rubber on the rollers. The tracking system was always touchy. I had a clunking in the upper rollers that I finally traced to the bearings slipping in the casting. Loctite was the cure. It used to throw the motor pully no matter how I tightened the set screw, until I replaced it. I have used it for many years but I have no great attachment to it. If I came across a good solid Delta, at a good price,like we had where I once worked, I would buy it in a heartbeat.Might as well post my 113.
I picked it up for nothing as the upper roller had cracked where the left side bearing mounts. The rollers are discontinued so my father milled the hole deeper to seat the bearing in fresh material. It had worked for years, but its starting to get play again. Anyone have a good upper roller?
Grizzly is pretty good. Call them and I am sure they wiil give you the info. If it is bigger, you can sleeve it without needing a machine shop. I had to do that once and cut a window in the sleeve for the key.You might be interested in this.
I found this 9" Cast iron disc from Grizzly that could make for a cheap $29+ ship. replacement. It's cast iron which is better than the hard to find aluminum versions floating around. I haven't checked yet but hopefully it's the same diameter spindle hole size. If it is the same spindle size (cross fingers) then I'm luck I think others will be too.
http://www.grizzly.com/parts/P1014Z021?utm_campaign=zPage&utm_source=grizzly.com
It's for the G1014Z Combo sander:
http://www.grizzly.com/products/G1014Z?utm_campaign=zPage&utm_source=grizzly.com
This got me inspired to take another look. The cheap pulleys did not seem to run very true. The belt seemed to get tighter and looser as I rotated it by hand. It does not look like a bent shaft at either end. There was some belt delamination. I am going to order some machined steel pullies and a power twist link belt. It was a bear getting the pullies off. Glad I have a puller. I am also going to look at the motor start cap that may have deteriorated after all these years. I don't know if 3/4 hp is marginal or not or if Craftsman 3/4 is like real 3/4 hp.I have a later one with an aluminum table. There was a lot of vibration from the aluminum idler roller.The press fit bearings were slipping in the casting. I forget what I used but rhe right stuff is Loctite 609. The 3/4 hp Craftsman can barely start the belt. Have to look into that.
Beautiful job. I have Cman jointer on a stand of similar vintage. Wish I had the belt guard.Heres the link to one I restored recently. Fun project and its a great old tool.
http://ecmanufacturing.weebly.com/woodworking-machines.html
I have two of these complete one is currently in use. Very nice job on yours I'm curious how you cleaned up the work tables so well they look new. Like to get mine looking the same.
I have that sander and I spent a lot if time chasing a vibration from that upper roller, when I bought mine, new. I finally realized that the pressed bearings were very loose and slipping. I Loctited them in for a fix. I don't remember what I used but today it would be Loctite 609. It fills pretty big gaps. It is made for worn shafts, bearing seats, etc.Might as well post my 113.
Hi Macgee,
Is this the one that you ended up using in your pictures on your next post? I'm still on the search for mine. I found a couple of them but they're all $70+ which is more than I'm willing to spend on a $5 sander...
