Mystery Klein tool?
Jason280
Picked this Klein up earlier this week, can't figure out what its for....its opened ended with flats, and threaded on the opposite end. Any guesses?
SilverDeck
Coax/F Connector
Nailed it! For hooking up co-axial cable. Use one from time to time at work to connect/disconnect the fittings to deeply-recessed grommets in wall plates. It's one of those specialty tools that is a godsend when you need it!
FigureItOut
Bentonville AR
OP, is there a part number on that? I want one.
Edit: Found it. It's discontinued but I found one on eBay for $18. This'll come in handy.
Sent from my SAMSUNG-SM-G930AZ using Tapatalk
FigureItOut
Bentonville AR
Ideal makes one, too. 35-046. Around 18 to 20 bucks.
Thanks, just ordered the Klein. I have the Ideal BNC tool, didn't know they had an F connector version. I wonder why Klein discontinued theirs.
teddlett
I'm not sure about the residential/construction side of thing but in the entertainment industry, anything that used to be an F connector is now ether BNC or become an RJ45. Though I personally prefer the stuff that's switched over to EtherCon.
Sent from my XT1650 using Tapatalk
WildwoodChuck
Peru Indiana
I loved this when I was doing data cables a few years back.
Two Speed
Ontario Canada
That PT540, I would have loved to have one of those a few years ago when I never knew what I was going to run into cabling wise. Actually, now that I see it, I still want to get one.
Alex.
6PTsocket
Every TV that I have seen since 300 ohm flat wire went out of style and the cable company seem to be committed to F connectors. It is clearly not the greatest, using the cable as the center conductor but there sure is a lot of it.
teddlett
True, the last time I used an F connector was when I hooked up my Tivo, but I'm guessing that in the next couple of years TV's won't have them any more ether as they become displays without tuners.
loudog212
Lancaster, PA
Cable guy here. While that tool might not be widely used in the home, cable headends are 80% coax. That is a VERY handy tool to have when you need to connect a cable in the back of a rack that has a few hundred cables in it. Finger space is often limited and when you get the motion down you can connect and disconnect a cable in seconds with it. Here is an example of where it might be used, and this rack is only 1/3 full
NoahG
Detroit, MI
Super useful in patch bays. Some people call them a 'Trompeter' after one company that makes them.
decableguy2000
This place to use those tools. That rack is only partially full, keeps from getting alligator bites on your arms from the zip ties.
48RON54
Inland Empire, CA
Thanks for posting. I inherited one of those with a tool box and was wondering what it was for. I thought maybe drum brake tool but the Klein written on it and the threaded end had my quite stumped.
