Best source for URD cable?
PCustoms
VT
Find a local distributor and call for a price.
Mine has blown away HD and the online places by 20% fairly consistantly
pattenp
Virginia - USA
FYI, URD has to be terminated outside, is not to enter structure.
Try WireandCableYourWay.com
How much power are you planning to feed 250'.
pattenp
Virginia - USA
We are running 100 amp service to the new shop.
At 250" you'd be better off using Al 2/0 for 100A. Are you planning to do conduit or direct bury? 2/0-2/0-2/0-1 MHF is a good option if doing direct bury but can go in conduit. XHHW-2 is another option but does need to be in conduit as it's not direct bury rated.
edit: both MHF and XHHW-2 can run inside the structure but need to be in conduit where above ground and inside.
J
Jhenry1745
Northern WI
Thanks for a he reply. Please refer to my other post regarding alternative cables.
