curliejones
- Joined
- Aug 19, 2013
- Messages
- 34
Thought I'd reach out to you mechanical types to see if this idea is good? if there's a better way?
I recently built a drill press table with a fence to help in my woodworking and quickly got tired of taking it on and off my 35 y.o. Taiwan Orbit floor model. I rationalized a new drill press (d.p.) since half the time the Orbit had metal shavings and oil on it and picked a 10" bench top that can handle most of my woodworking chores.
The thought was to leave the drill press table in place. In hindsight, I might have opted for the 8" Wen WITHOUT the rack and pinion (r&p) but that is such a nice feature and bigger, faster, more features is always better right? Almost always, that is. What I did not realize was that the drill press table would interfere with the handle of the rack and pinion and the drill press table need to be removed to adjust the table height. I've measured the rack and pinion shaft at 1/2"o.d. and it is round with one side flattened for the set screw found in the handle assembly. The r & p is very smooth and the table is light on this small d. p. so I believe that extending the handle shaft outward 6" would make the thing function properly.
It took some digging, since I'm a carpenter /homesteader DIYer more than a mechanic but I found a motor coupler or two with 1/2" bore and 1-1/2" long that has two set screws. If this were affixed to the handle shaft on the d.p. and then onto a 6" shaft, I could get outboard of the d.p. table. I see aluminum rod available in 1/2" d. and I think after flattening a spot for the handle's set screw, this would serve as my extension. Looks like around a $20 job, well worth the convenience. If you have suggestions or thoughts on what I've proposed here, I'd really appreciate your input!
