3/8" Breaker Bar
SRSemenza
Hi,
Looking for a 3/8" drive breaker bar that is something more than 12" long, with smooth or grip handle but not knurled. I see that Snap On has a long one (17 or 18) and Harbor Freight has a 17". Doesn't need to be 17 + but at least 15 would be good. 12 Just seems too short.
Is the HF one any good? I have read lots about the HF 1/2" drive but .............
Seth
Tenex
You might have better luck finding an extra long 3/8 ratchet.
SRSemenza
Snap On has or had 15" in 3/8" drive? And the 17" would be OK too, price tag is the only hold back there since it won't see much use.
I might reconsider my general dislike of knurling looking at the SK. :)
Reason for the 3/8" drive is head size. I couldn't fit a 1/2" into a spot where a breaker bar would have been perfect a couple days ago. But I am pretty certain a 3/8" would fit because the 1/2 was only about an 1/8" too tall. It was the fork on handle style not the oversized other way around type.
I have an 11" 3/8 drive ratchet that fit but a little more oomph would have been welcome. :)
Seth
mrborohachi
Berdoo Route 66
Stanley and husky have a extending handle 3/8 that has a fairly small head.
It's the #1 ratchet. I don't think Husky even sells that ratchet still, but I have seen it in WalMarts.
http://www.trucktrend.com/news/1210tr-truckin-tough-3-8-inch-ratchet-test/
I do own a Snap-On frankenstein long breaker bar. I had a Long 3/8 breaker that one of the forks broke. Took it on the truck and the dealer hands me a short one. I was like my breaker is a long handle i'm not taking that short handle breaker. He dug around really quick and found a handle to a long flex head 3/8 and put the square drive in the handle.
Mr_B
Reading
^ yeh I like knurled stuff
If OP want cheap and not using it every day the pittsburgh pro will do job and got lifetime warranty for when does break.
theoldwizard1
SE MI
Skip the breaker bar. Get a 3/8" flex head ratchet. About the same length and SOOOOO much more useful !
wmm2
Cincinnati, Ohio
I know you were asking about 3/8 due to size, but what about the HF 1/2 extendable ratchet? It goes to 17". I have one and it's come in handy sometimes. It's got a little smaller head than my 1/2 SK breaker that sounds like the same design you said was too big. I use mine more for the reach than the leverage, but it might work for your purposes
cliftonbros89
Missouri
I have the SK 15" and it's great. Also have the Matco 15" as well, it's good too. Both I believe were cheaper than the Snap On. I have the shorter Snap On. It's good for where the length of the SK doesn't fit.
vssjim
McLean Va.
I used my fairly new SK breaker bar today on some trans and diff oil plugs on a toyota and the knurling is not really rough at all. I would go with the SK again with out a second thought
ryan20021982
Northern IL
All smooth handle
Titan Tools 12019 18"
Matco B15EFHM 15" pressed on handle
Neiko 00338A 15"
Dewalt DWMT17136B 15"
Westward 5TZD9 15"
T&E Tools 13FH 15"
Tuc04
Koken makes a 15" smooth handle 3/8 drive bar. 3768P-380
pendragon1998
NE Georgia
Considering the size of fasteners for which 3/8 is appropriate, I think you're likely to break or round off the heads before you break even the HF bar.
visionguru
Chicago
All smooth handle
Neiko 00338A 15"
Westward 5TZD9 15"
T&E Tools 13FH 15"
That's a good list.
I have this no name 17" flex 3/8" drive ratchet, more for leverage than big torque. Paid $15. So far so good, but I would not consider it a break bar, anything more than 80ft-lb, I'd use 1/2" drive.
vjquan
The HF 3/8" bar is really a 1/2" bar milled down, so the head has a 1/2" yoke. The 3/8" ratcheting breaker bar would be ideal if it had a standard head. It also has a far nicer chrome finish.
Dave455
Sussex, England
I have the KoKen one.
Decent tool, and reasonably priced!
Same tool is sold by Beta as part of their aerospace range, or somesuch, but it's more money buying through Beta!
cherrybomb
Near Madison Wi.
It really wouldn't be a bad deal IMOO to have two different lengths of bar to fit possible situations.The price of a deluxe ratchet lasting a long time is the solution I'm after.
SRSemenza
Aah, now that's a good piece of info to know since I am after the 3/8 due to head size.
Thanks,
Seth
SRSemenza
Ryan , thanks for the list.
I will look up that Koken as well.
And thanks so far to everyone else.
Seth
Schurkey
I really like my Snappy roto-ratchet. Longest 3/8 handle I own.
All depends on what the OP is loosening. I have a scrap 3/8 drive long handle Armstrong ratchet because I used it instead of a breaker bar.
Armstrong :(
In general, I despise breaker bars. Therefore, if someone asks me for a recommendation for a 3/8 breaker bar, I'd tell them to buy a long-handled 1/2" drive ratchet.
SRSemenza
That may be a good rule of thumb in general but there is no way a 1/2" drive ratchet and socket would have fit in the space I could have used a 3/8" bar.
Seth
Mr_B
Reading
Thanks,
Seth
Pittsburgh pro 3/8 nothing like the 1/2 version .
Saw a 15" Dewalt one couple weeks ago on sale around 13bucks with life warranty (whatever that entails from dewalt!) was nice design/finish for the price .
1foxracing
Tuscarawas Co, Ohio
Wright makes a smooth handle 3/8" Model 3439
https://www.harryepstein.com/index....8vLlWBl2_v0-Ne5dDpO6U4w5kvx0oxNhoCA5sQAvD_BwE
MhOzkRgCP8o-YSb_veSKcv7E5Bdd_OyPZGlbuQLLcRjme4CxiyYGoOB-cDkxtKyXCJNMgklNkZdmwyEbeYo1oIED7ehxMu5aX24O2EA0vzlR59elFIBw-Zbvnn93KnJMcG9mD9u2aT5AcFYESOWQWdou8se7OuCNhD7mMLCjRsHT32HGIcit27jXaXeKbcbUa9WfWp7EGHwhYYh0VKf_3SxIVZrtQiBLH0sQlnxKuHOM3TWWWv0I5ysXJzfObrxJyeetHb11XjfAbK5JS_VrHsxZ9tQ0eDshiBtgPHTSUkVXha-PtsQQLVd46thL4vGXSJlqbg6H61Zoq9d-F5lu_LzqYlVY3vZGTtR602CtJOyIC16-N7bp7-iDgi4CO4gzR82_rkSylwa-nXEtJw6oCOVpqfauHNNhT1993xh7AX2_eHCqxxQNse16uyXl8nyYGnl8TFVJAu_zrICWtQyOI-ykNkycSLBc9gx-02sLfVZx-KYHd9TygC3O8sD8eO_um5kXgNjxrTT1AHaVu9RFiUk8ldKZM-GKHXLEVKnEvDMzICqWU8NixAxKPM9kF4tI8f6Tl2Rl7XkpzJdL1anHl51UR_BC5QPPpuBOa6KyB__edIpn5f8zgz8owg=w1920-h447-no
dnschmidt
Phoenix, AZ
This one isn't even close. The Harbor Freight is 18" long and perfect for what apparently what he wants to do. I keep one in my car for serpentine belts. Unless you're a gorilla you'll never break it and if you do you walk into the store and they give you a new one. This is without a doubt the way to go. Oh, and it cost like $10.00. No contest here, HF in a unanimous decision.
Schurkey
...that's when I use a long-handled 3/8 Snappy Roto-Ratchet. Snap-On says it's only a foot long, but it's way longer than any of my other 3/8" ratchets.
Yes, a breaker bar is more compact. I still hate 'em; and managed to live without a 3/8 for my entire professional career, along with my subsequent hobby "career".
I am not part of this "unamimous" decision. Won't set foot in a HF.
