How do I ID this compressor?
AirToolMan
I know it's a Ram Air.
I inherited it and thats all I know about it. Where do I find info on it?
What I want to know is:
1 or 2 stage
max psi
size, 60 or 80
model #
where to find parts for it, when that time comes
Infinia
SoCal
Find and post an image of the tanks regulation tag. It's usually tack welded on before final paint.
Get a reverse image of the pump. the electric motor ( ~3.x HP) gives the least clues about the original OEM.
MacMcMacmac
canada
If it has an air filter on both cylinders it is a single stage.
I'd need a good shot of the pump, but initial wild-assed guess is it's a Campbell Hausfeld product according to the flywheel shape.
Olafur
Iceland
1 or 2 stage
max psi
size, 60 or 80
Note: I am not familiar with the compressor you have.
But recognizing single or dual stage is easy. Single stage have equal size cylinders - both cylinders pump the air directly to the tank. Dual stage have the primary cylinder much bigger and that one pumps to the intake of the smaller one. Usually through some kind of cooler. Smaller one then pumps to the tank.
Judging from your pics you have single stage. 3kw motor approx 4hp. That equals roughly 400l/min or 14cfm. Probably conservative number.
Infinia
SoCal
I see YR. 1986
from their website. Campbell Hausfeld purchased the Melben Products Company in 1961 and begins to manufacture sheet metal products, including air receivers and paint tanks.
200 psi tank infers ~175 psi operating so into 2 stage territory for CH
post dimensions of the tank http://alloiltank.com/tank-volume-calculator/
A
AirToolMan
info I found shows its a Ram Air make, sold/marketed by SnapOn. It does have a Ram Air decal on it.
MacMcMacmac
canada
This is definitely a Campbell Hausfeld product.
Try looking through the various CH drawings at Master Tool Repair. You might track down the model that way.
