Thanks !
If you look for the extractor set search by "Ridgid" cause kukko and belzer would be mopre expensive.
The shorts are also made somehow in Europe
Thanks !
Thanks !If you look for the extractor set search by "Ridgid" cause kukko and belzer would be mopre expensive.
The shorts are also made somehow in Europe![]()
Facom made Craftsman screwdrivers?
[/QUOTE]nice :thumbup:
[URL="www.husqvarna.com"]Husqvarna[/URL] 536LiHE3 battery pole hedge trimmer
[img]http://up.picr.de/29915669lc.jpg
main handle and rear handle
vsr trigger switch, on/off and energy save button
(brushless) motor housing/gear case
aluminium gearcase
all metal joint
pull the grey sleeve to adjust the head
professional blades
carrying/storage position
Bolt pattern measuring tool
I have this ratcheting wrench from Facom and I am not impressed. It is very rough and tight and the backdrag would make it non usable for anything else than undo a bolt.
Anyone can provide some feedback if the reversible angled ones are better/ smoother and how they compare to Gedore reversible?
Thanks!!!
Sent from my SM-A510F using Tapatalk
First of two orders arrived from TBS Aachen
And who is the OEM for Wiha[emoji16]
- some Dynasteel wrenches (Dynasteel/Dynacore was made in Belgium, went out of business in 1965, so these are old).
- Facom wrench and bits: Facom was my father's 'brand', I'm sure he has the complete set and much more in the other boxes. It's the good old French made Facom.
- Acesa (Spain) wrench
- Fiat wrench (the garage was
- Some knipex pliers
- Rheidco Metabo wrench
- A NEON and MITO wrench, couldn't find anything on the net about these brands.
- The red screwdriver has a logo I've never seen before. Says 10000 volts Germany on the other side.
I'll do my best to make better pictures next time. Will be looking for a Facom toolchest in the near future![]()
That would be a good tool for me to have in my line of work. Who makes it?
Gedore´s are probably the roughestAnyone can provide some feedback if the reversible angled ones are better/ smoother and how they compare to Gedore reversible?
I believe they are made by specialised companies.Who is the OEM for the striking tools? Does Stahlwille makes their own hammers?
I think they are the right tools.If you work on CV joints then you definitely need the horshoe kind of spring pliers or do you have any other option?
WihaAnd who is the OEM for Wiha[emoji16]
...or...:Are the pliers below the correct ones for the VW hose clamps?
I think Wiha is right. The Stahlwille recoilless hammer should have a small hex symbol stamped into the hammers metal sleeve. Just like Wihas symbol...
They´re made in switzerland.
Does anyone knows where to go for tools in Berlin and Frankfurt? Nothing in particular, just good tool stores.
In Berlin I think you can visit SATBerlin and Zoro.
Frankfurt you may try City-Tools GmbH Zentrale Frankfurt, they are closed on Saturdays and Sundays though.
Address: Königsberger Str. 23, 60487 Frankfurt am Main, Germany
Also try and google "Uhrmacherwerkzeug" in Frankfurt, Berlin etc.
In my experience handtools you may have at very good price in Germany but power tools more expensine than in UK for example.
Hi Wizard1,I have a hose clamps plier for VW&Porsch .
Hi Wizard1,
I cannot see your photos due to photobucket issue probably.
Could you just upload one photo of your pliers or the brand and model number to have a look?
Thanks!
Ok Try again.
Fake Stahlwille Wrenches?
Wurth brake cleaner made in Germany
Ok I can see it now, Mubea GO 291. Difficult to find one.
Thanks!!!
