US Jack jackstands are now rated per PAIR. It has something to do with wording of new safety standards and that jack stands are designed to be used in pairs.
See post #15: https://www.garagejournal.com/forum/showthread.php?t=335521
US Jack
3, 6 and 10 ton models.
Can I use just one on an axle? Some times I work on just one side at a time and leave three wheels on.
I do that occasionally for brake work but I put the tire under the pinch weld and keep my floor jack in place as well (with the weight on the stand). Keep your limbs out from under the hub/rotor/etc.
If you are getting under the vehicle use a minumum of two jack stands and wheel chocks.
Why should I use two jack stands as suppose to one? If I'm using just one jack stand I also place the floor jack under the pumpkin and place the tire under the frame on the ground.
