Shop/Garage/Pole Building budget???
rjacobs
Dallas, TX
Basically looking to see if I can stay in my budget and do what I want or if i need to stretch a bit more.
I know prices vary all over the country. I am in the Dallas area.
Im looking to buy a piece of land shortly(next 6 months) which may or may not have any utilities on it. I need a place for storage mostly at first so utilities isnt the top of my priority list.
I'm thinking I want to budget $50k. This would be building, doors and concrete/site work, no electrical, no lights, no plumbing, etc... I may try to do a few things setup in the slab for say a bathroom rough in or an electrical conduit for a panel.
I want to build a 40x60 building. Dont necessarily care about the method of construction(steel, wood, etc...).
6" reinforced concrete. I want a lift. I may want a few machines later. I will want to be able to pull a 45' coach inside. I dont want to have to think about or regret doing 4" later.
16' interior height.
3 "garage" type doors. One 14x10, the others I am thinking 10x10, not set on width though. At least 1 man door, if not 2.
Those are the basics.
We dont have a Menards close by, but their building estimator for the above(minus concrete work) was ~27k. I believe thats a stick built structure. Im guessing concrete would be 10k-12k.
Anybody think my 50k budget is out of line?
matt_i
SE Michigan
Seems reasonable to me, however if there's a massive residential/housing demand, a large percentage of the building trades may be engaged in potentially more profitable work. ~$20/sf is on the low end but you don't have much other than concrete, frame, and metal.
Best plan is to start a document of specs and sketches (even if scanned or phone photos of pencil drawings) that you can send out for bids. Get 3 to 4 bids and you will know if your estimates are possible.
I am going to recommend a 12' wide door. I am assuming your coach is 8'6" wide and that only leaves 1'6" (18") of total clearance split between the sides. That would make a nervous affair to back in (or back out) a $$$$$$ vehicle. My other experience (this is backing a gooseneck trailer into a dark, unwired building, in bright daylight, sun directly overhead) is you definitely need a spotter. Its like looking into a black hole from the driver's seat. It may be worse at night although the vehicle's running lights could help.
robmartinson
Spokane, WA
I just spent $14k even on a finished 2400 sq ft, 6" floor with rebar and two 4x4 man door pads in Eastern WA 60 days ago. I did 90% of the prep, but did have them compact it.
DCarr2
Akron NY
last march i spent $7,000 on a 1650 sqft 5" floor...
and about $500 on paint..
to insulate and finish off the ceiling will be another 3-4K
I found, that in Buffalo NY, pole barns run around $50/sqft
johnehr
Oak Grove, Minnesota
One option to help with natural inside light is to specify "eavelite" polycarbonate at the top of the walls. I have 24" on my pole building and during the day it is amazing how much light the sun provides into the building.
Catadj78
Alabama
Wow.
I spent less than 7k on 1600 sq ft finished out a year ago I believe
R
rjacobs
Dallas, TX
So it doesnt sound like my budget is out of line.
Hopefully I can get this moving along in the next 6 months, but we will see.
I have looked at a hand full of pieces of land and havent seen anything I thought was great. Best thing I saw was a bit far from me at 45 minutes, but it was also 30 wooded acres. There is a lot of farm land being divided up into 10 acre or so plots around where I currently live... Its "boring" and im not looking to have a horse ranch or whatever where the flat acreage is a plus.
OneOfEm
I also started with a budget (pretty fixed budget) as a starting point.
I found that for that money, I could get a significantly lesser building built by someone else completely, a lesser building purchased as a kit where I did some of the work, or the building that I want if I do all of the work (or nearly all - I hired out the concrete finishing). I chose the third option.
Time or money.
BoostedOne
Osteen, Fl
Dont forget to include site work. Building the pad for the building costs money too. For a 40x60 you might have 1500-2000 in dirt and machine time.
5000psi concrete here is about $150/yard last I checked. 0.5x40x60/27=45 yards. ~6700$. Plus your footers(5-7 yards). Plus labor.
blair683
I don't understand these cheap prices. You guys must be building the cheapest building possible. I am guessing with these prices you guys are are doing 4' or more spacing on trusses, all steel exterior, and 4"x6" posts? I built my 27'x30' with 6"x6" posts, 24" centers on trusses, shingle roof, and vinyl siding. My overhead door is 16' x 9' insulated. I have 10k in just materials. I built myself and contracted the 5" concrete with remesh and a drain. The concrete alone was $3700. I'm in mine pushing 15k and my interior isn't finished yet. A lot of these prices on here are misleading in my opinion. How could you build a 1600 sq ft building for 7k with 5" of concrete. The concrete alone would be 5k.
cj7jeep81
S.E. Indiana
I built a similar sized one a couple of years ago, 40x64x16 with 6" of concrete. I had some family help, which cut the cost down a good bit. All told, it cost me about $35,000.
Materials were $22k, and that included trusses on 4' centers (with 2 of them being scissor trusses), laminated columns with perma columns, wainscotting, 2" blanket insulation on all walls and ceiling, two 14x14 insulated doors, and one entry door. I think I paid 3k for labor since I and family helped. Concrete was around 8 or 9k I think (saved a grand or two on labor on that as well).
I also got quotes from a local Amish place (so no breaks on price), and it would have been a bit over $40k that way.
n20junkie
Grand Island, NY
Not a pole barn, but a stick built 30x50, with a lot of the prep, walls, plumbing/electrical all done by me, still cost 60k for a box with electrical. No insulation or interior.
R
rjacobs
Dallas, TX
I have had good luck with FiveStarr builders. They put up a 30x30 and a 30x40 for me and will be building another 30x40 soon.
They did a great job every time.
http://fivestarrbuilders.com/pricing-guide/
I was just able to get onto their website and see pricing. Damn internet restricted countries...
just shy of 28k for a 4" reinforced pour, 40x60x10 with a single overhead door and a single man door. Not bad. Im guessing going to 6" pour wouldnt be that much more expensive and same with going to 16' vs. 10'. Add a bit for more/larger over head doors. Add a bit for dirt work. Should be able to stay under my 50k budget.
dv8customs
East Texas
If I remember right they told me it was $1,000 per foot to add height so that's another $6k.
R
rjacobs
Dallas, TX
Thats not bad... Im honestly trying to justify the 16' ceilings, but im having a hard time.
I want to do it to put the 14' door in to get an RV in(which I dont own currently, but want to some time in the next 10 years), problem is I want to finish 20' of the 60' span into an office/living space/bar/bathroom/etc... with either storage or a bedroom above. Which gives me a 40x40 garage/shop space to work with. WELL a 40'+ coach obviously doesnt fit in a 40' deep bay SO at that point do I go to a 50x60x16 building OR do I not do the 16' ceiling and just do a 10(or maybe a 12')... If I dont do a 16' ceiling I also probably dont need to do a 6" slab so a 4" would work with a few places done thicker or with piers to support a 2 post lift, so again, saving money.
Falcon67
Merkel, TX
If you EVER expect to need utilities, you best check that out FIRST before you buy any plot. If there is a water line, your connection can cost - just for the hole and meter tied to the line - $1000 or better. If they have to run more line, 10x that. Same with power. There might be a pole close by - but it might also be $100/ft to run a drop and set a pole. Or no cost if inside a certain distance. Septic field and tank can easily go $10K plus. Shooting a well is a **** shoot that can set you back $3500 or more for a dry hole - you pay whether you get water or not. Your neighbor 1000' away might be able to water their whole property at once and you get a trickle.
