I agree with the above posts. Stay away from cheap units and go with a quality machine. Spend the extra money and get a gas bottle. The flux-core wire has its place, but I haven't talked to anyone yet who isn't more happy with gas welds vs. the flux core. My .02
jetbtdvr,
I asked a similar question a week or so ago. If you have enough in the budget for it, take a look at a Miller 211. It will run off of 110 or 220 by changing the adapter on the end of the cord (supplied with the machine), has the capability to weld up to 3/8" in a single pass, can use solid core as a mig or flux core if you are outside, you can attach a spool gun for aluminum or stainless welding, it's fairly portable, has the "auto set" feature for dummies like me and best of all, it's AMERICAN made.....
The local Airgas Company offered me a NICE deal on new one that I will be picking up this Friday. Total was $847.00 plus tax for the welder. I went there to just get a welder and wound up getting the welder, a performance helmet, a new torch outfit, 3 large bottles (oxy, acet, 75/25 mix) and an empty wallet...
The only drawback is the 211 is rated at a 30% duty cycle but I don't plan on using it in a production setting so it will be fine for my use. If I find that I need more horsepower later down the road, I'll go back and get a 252 or 350P.
Another good option for 220 only would be the 212 that has the same capability as the 211 minus the 110 option but the duty cycle is increased to 60%.
After talking to the guys here and several other sites as well as several local welders and welding shops, one thing kept coming up. Don't go cheap.... You will get frustrated, have poor welds, wire feed problems, did I mention frustrated???
Go with a Lincoln, Miller, Hobart (I think they are made by Miller), or ESAB and you won't regret it. I chose to go the new route and have a 3-year warranty but if I knew a little more, I would be tempted to buy used right now and replace the wear parts and be done with it. That might happen on the next machine that I get (want a stick/TIG later).
Have a professional welder weld it...you don't want the liability risk of having the welds break and causing an accident.I am looking to purchase a MIG welder. I have never welded before. My first project will be a stand for the welder. I would also like to repair my small boat trailer. So what are your suggestions for a first time welder
if the guy has any sense about him he will practice before he makes the weld on the trailer
depends.... do you just want to "get 'r done" or do you want to know the the technical aspects?
Wire welding, or Mig, is fairly "easy" to do, but with anything, the ****** is in the details.
It helps to know a few basic techniques. While you can learn from a book, at the end of the day, you have to actually do it. See if there is a very basic metal working class that you can take to see if you really like it. Call up the local vo-tech schools or even your high schools and see if that have some short night classes.
or heck, call up a local welding shop and see if you can "shadow" somebody for a little while....
You hope. I have seen lots of welds that were only caterpillars laid on top of the metal.
the local community college here has a decent welding school but the waiting list is like a year and its a fulltime course so its not for the hobbyist
if thats the situation around you id say get a bunch of scrap and start practicing...i learned from videos and just doing it...lots of wire and metal used but now im semi proud of my welds and i know they are strong as hell![]()
Buy the best welder that you can afford. A lot of people make the mistake of buying a cheap welder that will be "good enough" to learn on and find that they outgrow it pretty quickly, or find out that it's hard to learn to make good welds on a POS Harbor Freight machine.
Unless you only plan to weld sheet metal and you have the service for it, get a 220v machine.
I've got a 180 amp Lincoln, not a "professional" machine by any stretch of the imagination but I have found it to be quite capable of supporting all of my car and hobby work.
I'm sure that some of the more experienced guys here will chime in with their wisdom!![]()
While you are looking , try the fit and triggers of different guns. I use ESAB guns with flex heads. Different size grips and different trigger placement make a difference in the comfort and that makes a difference in weld quality
My next step will be a torch-mounted MIG light. It turns out that by the time I got good at laying down a bead, I couldn't see where I was putting it!!!
mig welding is not easy. its one of the hardest to master, especially with a 110 machine.
Hey, I'm the guy who bought the cheap machine! I bought a Century 110V MIG from Northern a few years back.
When I learned Oxy/A welding it took a while and it was never :set it and forget it". You had to know what you where doing and change everything for the conditions....
I won't say that you're not a "welder" if you've only MIG'd, but starting with Oxy-A sure gives you an appreciation for the new stuff!
