Show us Your Vintage Bench Grinders!!!!
MacInger
Los Angeles
A local Ace hardware should have wire wheels in 4" diameter. Try Amazon for the deburring wheels? :dunno:a
Wish it were that simple on the deburring wheel. Have about 40 open tabs of different sellers, went through all 220smth 3M scotch-brite products one by one. Can find 2 useful products but only available in cases of ten - expensive.
Norton likewise seems to have 1 finishing convolute wheel at 4" also only available in packs of ten.
I'll find something eventually :)
EOC_Jason
Bentonville, AR
I would just hop on eBay and search for phrases such as:
unitized wheel
convolute wheel
deburring wheel
Sort by lowest and price and go from there...
CrotalusAtrox
The Great Southwest
Found a 3/4 hp Ward Power Kraft obviously made by Wissota runs good but I will replace the bearings. Of course it is missing a tool rest what's new.
bagged89s10
CT
Picked up a 1/3 hp wissota grinder with stand bolted to a half inch steel plate.
CrotalusAtrox
The Great Southwest
Love the Wissotas I am running a 1HP and just picked up a 3/4 its badged Wards I am getting a stand built for it. They are dam close as nice as Baldors if not equal :thumbup:
bagged89s10
CT
Picked up this 1/2HP snap on bluepoint for $30.
7" wheels.
No idea why this was bolted to the side shield.
Anyone have any idea what model number this might be?
Anyone know how the inner guards come off? Last thing I want to do is break this thing.
Put the outer covers in my simple green tank for a couple days. All the paint and grime just fell off. Quick wipe down with a rag and rinse later..
bagged89s10
CT
Got this grinder for less than $10. I just wanted the eye shields.
bagged89s10
CT
Dug out the set screws and had time to get one guard off.
This grinder has some serious inner flanges. Had to use a puller to get it off.
It's even keyed.
In It goes to the the simple Green tank.
6pony6
VA
So I went to look at a drill press today, and this followed me home. Based on the serial number and limited research, I believe it's from the early 40's.
Runs very smooth. I'll need to change out the original plug, but I think I'm going to use it as is.
I paid $20 for it and sadly while researching the Cincinnati Electrical Tool Co, it looks like that may have shut down earlier this year.311bcf6500134c9921205de6f6ebee73.jpgfb04480ff00a7edd506becb24876bfed.jpgce6095dd07cca1bf4eb5ac89da5997fb.jpg
Mintgrun
Kingston, Wa.
Very nice Don!
I have no regrets, having paid $50 for a Delta like that.
It is the nicest grinder I own (of five).
Mine did not come with the shields though.
I recently bought this old Craftsman. Could not pass it up for $10.
It is interesting that it is only rated for 1/3 hp, yet draws 5 amps.
This 1/2 hp pre-block draws 5.2
Well, Hell. posting photos here is frustrating to me.
never mind, I guess.
torqueman2002
SE Michigan
RandyRanderson
Richmond, Kentucky
Does this count? Found it under a pile of junk at an indoor flea market. $10. After putting oil in it (it was bone dry) and making a tool rest, it works great. No markings of any kind, I have no idea who made it or when. The nut that holds the wheel on is 25/32 (finally a use for that old wrench haha)
tool_scrounge
Southern California
This not my grinder, but it is listed in the Grand Rapids, MI CL.
I have experience with vintage Craftsman Block style bench grinders; but, I have not seen a Craftsman as massive as this one.
https://grandrapids.craigslist.org/tls/d/craftsman-de-pedestal-grinder/6299823692.html
Wow - that is like no other Craftsman grinder I have seen. The logo is from 1953 - early 1960's. But I find no grinder like it in the catalogs I have seen online. Not all catalogs of that era are online however. Thanks for posting the pictures.
Sure it does! I have quite a few of those. they almost always work great once oiled up.
thehorse13
Jefferson County, WV
I have the same grinder in the same color. It's an outstanding grinder. I'd put it up there with the best of them.
bagged89s10
CT
I just sold it today and I'm already regretting it.
It was a smooth running grinder but I have just too many including a bigger 1/2Hp bluepoint by Kingston Conley which I'm currently slowly restoring.
bagged89s10
CT
Use the "Go advanced" or the "post reply" to post, then use the "paper clip" or the "manage attachments" to load pics in a post as thumbnails. You can also use the postcard/URL to link the full sized pics:
hemifalcon
Union Grove, Wisconsin
There is a similar one that just showed up for sale in Connecticut this week. I bet it's made by the same mfg.
https://newlondon.craigslist.org/tls/6290416957.html
The Craftsmangrinder it is amazing. I highly doubt there's anything similar between the comparable unit and that Craftsman. There are too many obvious physical differences in their appearance.
Smokeshow69
Just was posting my friends millers falls grinder! He inherited it and is in the process of giving it a new cord and grinding wheel! It has no wheel side guards but we can fix that! It looks like it was also mounted on a craftsman motor mount which is the same as the one on my table saw motor [emoji1]Wondering how old this is as well as if anybody has another nicer data plate or any original side shields ?
joe.striper
agawam, ma
This is my second one of these beautifully made Craftsman grinders that I found. Don't let the fact that it is rated at 1/3 hp fool you. this sucker weighs like 80 lbs and it is a BIG grinder.
I found this one in NY, paid $75 for it.
For those of you who haven't seen one of these before notice how the work lights are cast into the side shields. Just a work of art:thumbup::bounce:
MoparTrucks
Ozarks of Missouri
Picked this Black and Decker up for something like $20. Un-grounded plug and a bit beat but the motor was good and even the bearings were in good shape.
All I did was clean it, oil it, rewire it, paint it, add new wheels and build new tool rests and I have been using it now for going on 2 years. I have a newer Delta grinder that is not nearly as smooth or powerful. The Black and Decker keeps spinning for over 2 minutes when you shut it off, the Delta about 40 seconds.
drivesitfar
ALL: sorry for the bad picture, but picked up this one today and i think it had more of a stand or some other part of it underneath it. i can set it in a vise and turn it so it might actually work.
anybody own or see one of these? ask if you want better pics too cause i'm able to do that if needed.
cheers
MissileBear
Western NY
Both my B&D grinders are like that. Lots of weight in the shaft and rotors, and really good bearings.
My Craftsmans, Blue Point, & Baldors slow down in less than half the time that the B&Ds do.
Rileysan
Milwaukie, Oregon
Van Dorn 1/2 HP, 8" buffer/grinder. I haven't tested it yet as it needs a new plug, but the bearings have no play and the wiring underneath looks fine. Paid $10.
Brian
rickhigginshtbr
Lower Bucks, PA
I'm working on picking up my second one if this guy would freaking email me back! There's 4 up for grabs in Philly right now, all rough shape, I just need another eye shield!
wrenchguy
NW Indiana
cheers
goggle up sickle mower grinder. looks to me its a champion hay mower sickle knife sharpener. any markings?
hemifalcon
Cool.. haven't seen that style before!! Thanks for sharing!
454ragtop
Carver, MA
Scored this gem at the flea market today, runs like a top, the lights in the shields even work! Just checked the serial #, 1950 vintage.
