Epoxy Coat, two different Part B's
repomannwp
Help! Which part b goes with the colored epoxy, and which goes with the clear coat? The blue tinted hardener is labeled 394.15, and the clear part b is 394. See attached pic.
R
repomannwp
I called Epoxy Coat's off hours help line and left a detailed message...waiting for a call back.
R
repomannwp
Since I want to get going on my install, I'm going with the clear part b on the bottom coat, and the blue tint part b on the top coat, I'm guessing it's the UV additive that makes it blue. Yolo!
Kaizen
New England
I needed them today and no call back either. so much for after hours help
This is in my clear kit
Answer your question?
Kaizen
New England
This is in my color
R
repomannwp
Thanks Kaizen.. unfortunately, I chose the other way, I used the clear harderner 394 with my base coat today... it turned out completely awesome, so no worries, but now I'm going to hold off using the blue tint hardner 394.15 with my top clear coat until I can talk to someone at Epoxy Coat about it.
As for Epoxy Coat as a company.. well, I'm not real thrilled with them for the following reasons
1. NOWHERE on their website, in their documentation, in the FAQ, or really anywhere on the entire Internet is there any mention of two different hardening agents in their product. THe labels on the product don't say anything useful either.
2. In the hard copy instructions, it does say something to the effect "keep the contents of the base coat bucket together, and the contents of the clear coat bucket together", but um, you have to empty the bucket to get the instructions out, that say not to empty the bucket of contents. Gee, thanks brilliant.
3. It's readily apparent they changed their hardening agent product somewhere along the line, and did not change their documentation to match. There is nothing in the instruction book, or on the container labels as to the difference... is it really that hard to print "use with clear coat", or "use with base coat".. ??? smh
4. Their customer support *****. I called the 800 number during their open business hours, and I gave up after 30+ minutes on hold when it because obvious nobody was home, despite the greeting saying my call is important to them, please wait on the line until the next available customer support rep. I called their "after hours" support line, left a detailed message, and got no call back. F'ing worthless really, and thanks for wasting a half hour of my time on hold today
Shea
California
They used to have a good customer service rep who participated on this forum. She moved on, however, and no one really stepped up to take her place unfortunately.
R
repomannwp
OK, talked to Epoxy Coat today.
The 394.15 hardening agent has a slightly different formulation producing a slightly better base coat. But.... they confirmed, it really won't make a difference in most applications as long as your mix is very good and surface prep was done correctly. I was also told you can use the 394.14 hardening agent with the top coat with no issues.
They agreed on my feedback that the hardening agents should be better labeled and said they will talk to their operations people about it.
Top coat will go on today, pics to follow, all is well.
Armorpoxy
Surprised to hear that it doesn't matter...with our products if you use urethane topcoat hardener with epoxy= big problems! For exactly this reason we color code all of our labels so that it's almost impossible to mix up our primers, epoxies, and urethanes.
Glad you got it worked out!
