WhiffySpark
- Joined
- Oct 22, 2009
- Messages
- 6,252
I’ve never used an impact on a o2 sensor. Those threads aren’t much. Just take it to a shop
I ordered the 3/4" breaker bar so we will see how it goes tomorrow
Mapp wont get hot enough?
No such thing as MAPP gas any more. Hasn't existed as a commercial product for almost a decade.They make a yellow hand held propane torch, mapp gas.
3700 degrees seems plenty hot to me, I've used both the blue and yellow cans with great luck on cars.
https://www.fleetfarm.com/detail/be...nVmse2lFa7i4BTLSq6I8MMimZKP48oxBoC8AYQAvD_BwE
Propane (without bottled O2) is good for heat-shrink tubing. Isn't worth a **** for heating seized fasteners. Might as well use a Bic lighter.
https://en.wikipedia.org/wiki/MAPP_gas
Now they sell "MAP Pro" which you're supposed to think is the same as MAPP. It isn't. It's outright deceptive marketing.
I'm not sure where people think the o2 sensor is installed... it's not installed I'm trying to remove the bolt that is in the o2 sensor threaded part of the header
If you do any serous wrenching,and are worried about breaking a ratchet,and fine vs.coarse,get a breaking bar.Its that simple.
Are you trying to add a wideband?
I sold or gave away all my breaker bars, and bought quality ratchets.If you do any serous wrenching,and are worried about breaking a ratchet,and fine vs.coarse,get a breaking bar.Its that simple.
Torch that bolt head until it's cherry-red.
Let it cool.
Rip it out with an impact gun. With luck, you won't even need the impact.
Whatever works. I've done it both ways, and I've quit heating the casting.what you need to do is heat up the pipe itself around the bolt, not the bolt.
you are talking about a bolt extractorHaha, you prolly shouldn't touch a tool again. Just bustin your balls, what you need to do is heat up the pipe itself around the bolt, not the bolt. You can try a vise grip after that or they sell a socket that you can hammer on and it's acts like a claw when you loosen it. Good luck
"I" heat the seized fastener, or the seized plug, NOT the casting it's in.
Heating the fastener or the plug makes it expand. Heating it ENOUGH also makes it "soft and pliable", like taffy.
Because it's trapped in the cool casting, it cannot expand outward. It has to squeeze microscopically longer instead. It's permanently deformed. As it cools, though, it contracts in all directions. Therefore it GAINS clearance against the casting, while ending up just a bit longer than when it was new. With clearance to the casting, it threads right out.
Heat the bolt as hot as you can with a good propane torch - even if it takes 5 minutes. Then douse the bolt with your favorite penetrating oil. There's going to be a lot of smoke. I (and others) have figured that the rapid quenching with penetrating oil may actually help pull the oil under the bolt and into the threads. Or maybe it's just the oil rapidly cooling the bolt that helps. I don't know.heating cast iron what's that going to take about an hours worth of torch holding just for it to start glowing?
That was going to be the last step since it's destructive.Has anybody used a impact chisel on that bolt head?Just throwing it out there!
I did do that in the very beginning.. however I don't have any more koril and I have been using PB blaster I bet I would have better luck if I could get to the backside of the boltHeat the bolt as hot as you can with a good propane torch - even if it takes 5 minutes. Then douse the bolt with your favorite penetrating oil. There's going to be a lot of smoke. I (and others) have figured that the rapid quenching with penetrating oil may actually help pull the oil under the bolt and into the threads. Or maybe it's just the oil rapidly cooling the bolt that helps. I don't know.
Either way, I've had a lot of success using that method to get stuck bolts out, when just heat alone didn't seem to be doing the trick.
I did not think about the jammed in but I was thinking welded.. but that I can see no welding marks.. and Map gas is only what 130F hotter? that does not seem much of anything..I wonder if the bolt wasn’t the right size and it’s jammed in. Perhaps welded? Idk that shouldn’t be a huge deal to get out.
And heating cast with propane is light using a bic lighter.
Subaru want's $300 for a new section of that exhaust.. that's crazy.. it's hardly like 8" wide lol I'm not sure if a exhaust shop can get it out.Could have been welded inside? No idea lol
And we’ve told you those handheld torches are worthless. You need a real oxy setup
the breaker bar I was using was 24' long
