Closing machine shop acquisitions
Hiatt1991
Prescott, AZ
Just got back from a closing machine shop sale. The guy running it said the shop was his father's and since the son had his own shop, he sold off a bunch of duplicate tools. I got this Mastercraft drill press vise which works really smooth, a Snap-On, Bluepoint and Williams wrenches, some interesting pliers, some older Craftsman 1/2 and 3/8 socket adapters as well as a couple of 3/8 Cornwell and Craftsman ratchets. Not too bad for under $50.
<a href='http://i.imgur.com/xLZxv3u' title=''><img src='http://i.imgur.com/xLZxv3u.jpg' alt='' title='Hosted by imgur.com' /></a>
<a href='http://i.imgur.com/1uZsSlX' title=''><img src='http://i.imgur.com/1uZsSlX.jpg' alt='' title='Hosted by imgur.com' /></a>
<a href='http://i.imgur.com/P8YQANG' title=''><img src='http://i.imgur.com/P8YQANG.jpg' alt='' title='Hosted by imgur.com' /></a>
H
Hiatt1991
Prescott, AZ
If my old and tired eyes are still working today it looks like you picked up a Bernard pair of pliers...
http://www.sargenttools.com/About/Our-History/
Correct! Pretty interesting set of pliers with the wire cutter on the side. They have an interesting mechanism and they close with the jaws pressing directly together instead of at an angle like most pliers.
larry_g
oregon
I guess I should have said "X-Y milling table" but I plan to put it on a drill press.
"X_Y positioning table" would be a better term. I would suggest that you disassemble that table and get all of the oxide off the ways before they are damaged any more by moving them against each other and doing any more damage.
If you are planning to use this to mill on a drill press watch this:
lg
no neat sig line
H
Hiatt1991
Prescott, AZ
lg
no neat sig line
I plan on doing that. It was covered in metal shavings so I plan on taking it all the way down and cleaning all the moving pieces.
H
Hiatt1991
Prescott, AZ
Last find of the day was this old Craftsman vise with 3.5" wide jaws. $15
<a href='http://i.imgur.com/g8aZ6os' title=''><img src='http://i.imgur.com/g8aZ6os.jpg' alt='' title='Hosted by imgur.com' /></a>
Kenwc
This is an Atlas version but they clean up nice.
Kenwc
On the handles I used a buffing wheel and Mothers Metal Polish Any parts that would fit on my lathe I polished with Mothers while they spun.
H
Hiatt1991
Prescott, AZ
Do you need to coat the metal at all to keep the finish from rusting? I live in AZ so rust isn't too bad out here.
Kenwc
No I didn't coat them with anything. However...for some reason I just don't have a much of a rust problem in my shop which is strange because I live in Dallas. I've also noticed that "stuff" polished with metal polish "seems" to take longer to rust. Others have said the same.
CalsXS2
On that vise. Is that sold as a Master craft brand or was that just the company that sold them and stuck their logo on it. Like car dealers do.
Here's my Atlas that I just got for $40. Looks just right on my 1936 Walker Turner drill press. It moves really smooth one direction and real stiff in the other. Needs a good cleaning. Are the gibbs easy to adjust?
Provincial
Near Salem, OR
Metal polish often contains a wax which leaves a coating like car wax on the part. This is especially true of chrome polish. I believe that the wax is the carrier for the polishing grit.
H
Hiatt1991
Prescott, AZ
Honestly, I'm not too sure. I just got it today so I don't know a whole lot about it. I messed around with it a little and it operates pretty smoothly but I plan on taking it apart and giving it a good cleaning and oiling like I do with all the used tools I buy. I'll do some more research on it though.
H
Hiatt1991
Prescott, AZ
Good to know. I figured there had to be some kind of mild "sealer" or the finish would gather rust/oxidation pretty quickly.
Dennis Leigh Henry
South Central, IN USA
Another excuse to get a new tool!
That makes sense... I know that polishing on a lathe with finer and finer "emery" cloth gets the same met effect polish wise.. I'm wondering if there is something about having a smooth finish keeps the "pits" away and therefore prevents rust some that way too..
Like you said though.. more research (and understanding) is needed... :rocker:
454ragtop
Carver, MA
Mastercraft is the manufacturer, made in CA if I remember correctly. Very nice quality.
gungatim
west mich
I got a set of those at a yard sale for 50 cents this summer, I thought they were fishing pliers since the guy had a ton of fishing stuff...they are unique for sure...
H
Hiatt1991
Prescott, AZ
Here's the before and after of my 3.5" Craftsman vise I got last weekend at a garage sale for $15. It was my first restoration and I think it came out pretty well. I couldn't have done it without the help on this forum. I used a wire wheel to strip it down to bare metal. Then I masked everything off and gave it 4 coats of rustoleum enamel paint.
<a href='http://i.imgur.com/UaTTNFK' title=''><img src='http://i.imgur.com/UaTTNFK.jpg' alt='' title='Hosted by imgur.com' /></a>
<a href='http://i.imgur.com/zSOWSnq' title=''><img src='http://i.imgur.com/zSOWSnq.jpg' alt='' title='Hosted by imgur.com' /></a>
CalsXS2
Hey Kenwc.
I see you have 2 long rods with wing nuts on them. I assume there is also a nut there double nutting the wing nut and you use this to loosen/tighten the rotating table, and move it with the long rods? Am I close,,,lol.
H
Hiatt1991
Prescott, AZ
Here's the vise with some white accent. I don't have a real steady hand but I don't think it came out too bad.
<a href='http://i.imgur.com/PVoux7l' title=''><img src='http://i.imgur.com/PVoux7l.jpg' alt='' title='Hosted by imgur.com' /></a>
<a href='http://i.imgur.com/uUndogc' title=''><img src='http://i.imgur.com/uUndogc.jpg' alt='' title='Hosted by imgur.com' /></a>
Kenwc
It came to me as shown below. The PO must have added these extended bolts to more easily adjust the gibs on that particular slide.
Hey Kenwc.
