a52-830
Personally, I'm waiting on the M18 jump pack.
now that is something i would be interested in . . . . .
^Suggested that years ago..
If im not mistaken you can use an sds like an air hammer with a chisel bit....or other types of bits.battery powered version of an air hammer would be the bees knees,
What I dont get is why dont they have the underhood light in M18? Youd think it would be a no-brainer.
m18 ratchet would be good too. Maybe not as slick as the m12, but it could be more powerful to make up for it. With a slim m18v battery, it wouldnt be any larger than the SO.
Before all that wild stuff how about a tire inflator blow gun combo. Ryobi makes them...two different ones actually. Give it two settings high pressure and a high flow setting. I don't want a tank that will defeat the portability point. If you want to copy rigid make that a separate tool.
Sent from my XT1635-01 using Tapatalk
Because then you have to drop 18V down into the nominal 12V range where most LED strips happily run. Adds more complexity and is less efficient than just using a higher capacity 12V battery.
Hey Milwaukee fanatics. I have been mulling an M12 3/8 ratchet for a while. Just about to start rebuilding my 5.4l 3v Triton. The reviews reviews I've read either seem to love them or think they're under powered. Anyone here use one on a regular basis. What are your thoughts? I don't own any M12 gear so I would need to buy batteries, charger etc. Are they worth it or should I just stick to hand tools or a pneumatic ratchet? Thx in advance!
Sent from my XT1635-02 using Tapatalk
Gotcha! So it can be used a regular hand ratchet then power can be engaged when loose. OK makes sense. I imagine it's great for putting things back together. Starting bolts and the like.If you incorrectly expect it to break fasteners free when you pull the trigger, it's underpowered.
If you understand it works like a normal ratchet - ie pull on it! - and then pull the trigger after you've broken the fastener free, they're fantastic.
If you don't mind air hoses and have a nice air system, go pneumatic if it floats your boat. I can't stand air hoses in the engine bay, they're always knocking something off a cowl or core support or or or ......
The sds is much larger but I don't think it could be the same size....heck... Just the battery is close to the size of the smaller air hammersSize comparison between an air hammer vs sds hammer drill
Plus is there any reason for an M18 there? So you could run it for 4 days straight without swapping batts?
Odds we will see 36v M18 tools at NPS 18? I cant imagine they wont go there, already behind, and even Hitachi has it now. Noticed the EGO 2 battery backpack blower, 600+ cfm but only 145mph, they all are moving one number up and other down. Gimme a two M18 battery backpack blower at 600cfm and 200mph damn it, then a two M18 mower, and six M18 tractor.... I have plenty of batteries
Amen it is so frustrating when a new battery line isn't backwards compatible and forward for that matter. As you said run 2+ batteries in parallel for high amperage....or in series for high voltage. It is the equivalent of DeWalts flex volt system but the batteries need less electronics and we don't have to buy new onesI'd love to see them do that...it's an elegant answer to more powerful tools without totally screwing over their customers with a new platform. They also don't need to develop new batteries or charger. A ton of benefits going this route. The new M18 lights with 2 18v batteries don't count since they drain them one at a time. That's a crock of ****. The Makita 18x2 system is pretty awesome and it's just getting started IMO.
Milwaukee is pretty stubborn though. They like to "stay within the lines" of the battery platform as much as possible. If they don't revitalize the 28v line, I bet they'll do a new higher voltage line all together. Or not at all. This is another area where I'd really like to be proven wrong!!!
What about a M36 batteries and a coupler that would connect 2 batteries to power a M36 tool ...granted not the most convenient for something like a drill but for something like a table saw...I'm thinking you can't let them use the same battery slot or people would drop an M36 in a m18 drill.
Also will you just rearrange the cells like DeWalt for a M36 4.5 AHr...or double the cells for a M36 9 AHr.... Maybe the switching flex volt type really is the future. That way all batteries are compatible with all tools (excluding size issues)
they need to make something similar to the ingersoll rand hammerhead.
Can you imagine using a 2763 inside the engine bay....maybe on an eighty's truck when you could stand beside the engine under the hood lolI think most leds run between 12 and 24v these days.. look at the 12v and 18v stick lights. I'm pretty sure those might be the exact same lights, and the additional voltage is what gives you the hi/low ability.. either way, the electronics needed wouldn't be anything significant.
MY GUESS, is that it simply makes more sense to make the under hood 12v cause that's mainly the area where a cordless ratchet lives, in the engine bay. So anyone invested in the ratchet is more likely to buy the light. The big impacts are more common for outside the engine area..
Theres a long running conspiracy theory that Fuel tools switch the voltage inside the tool instead of at battery level like Dewalt.
This is blasphemy but I have a Makita SDS Plus that takes two 5.0ah 18v batteries to operate and weighs 27 pounds without a bit. I prefer the corded SDS Max rotary hammer though because I can stick an SDS Plus chuck adapter on it when I can't find max bits. Most HDs and Lowe's don't stock max near me, just the supply houses, though I've been seeing some Milwaukee SDS Max bits turning up at HD lately.The sds is much larger but I don't think it could be the same size....heck... Just the battery is close to the size of the smaller air hammers
Lol I have the Makita 1/2in 18v that's similar. With a 5.0ah battery I couldn't imagine getting in the engine bay on most newer cars. Just laying on my back using it to do brakes or whatever my arm gets sore pretty quickly it's so heavy. If it can fit where I need it in the first place. Otherwise, it's a pretty mean machine.Can you imagine using a 2763 inside the engine bay....maybe on an eighty's truck when you could stand beside the engine under the hood lol
Just to give you an idea on how battery compares to corded. Last time I bring up Makita. Promise! [emoji846] My Makita 36v SDS Plus 1 inch can do 0- 5,000bpm and 2.2 pounds of impact energy with two 18v 5.0ah batteries. And I got my weight mixed up with another breaker hammer after yanking the manual it's closer to 12 pounds. I have an older corded 1in SDS Plus that does 4,500bpm with 2 pounds of energy per blow. So the cordless 36v 1 in SDS Plus Makitas are surpassing the corded 1in SDS Plus by a little. The SDS Max I have is a 2in so much larger. That one does 1,100 - 2,200bpm w/14 pounds of impact per blow. So the 36v SDS Plus has surpassed the corded. However it's going to take a lot of battery to match a corded SDS Max. No more talking about Makita now! Sorry!Very true. I recently moved across the country and ended up selling my compressor. The other day I needed to knock some pins out of some clamps, so I tried my 1" Fuel SDS with a pointed chisel. It actually worked awesome haha. If you're in a pinch and you have the room, a good SDS can get the job done.
However:
My air hammer (a mid grade Ingersoll, not even close to the best one available) is definitely more powerful and it is definitely a heck of a lot smaller in EVERY way. A cordless version would be so slick, but I honestly don't think it's possible. A rotary hammer IS what it'd have to be - it's an electropneumatic mechanism that does the hitting. Downsizing the tool means downsizing the motor and the components, that means less power. It can't happen. Air is king here. I'd love to be proven wrong though![]()
this is how rumors start right hereWait is this true?
Now that would bees knees. I'd buy that for a dollar.100% I got a stuck bolt I can't get off now it's somewhat rounded... does any cordless company have a air hammer that's cordless?
How soon till we find out the deals for black Friday for Milwaukee?
DerekV; said:1. Many people have many M18 batteries and zero M12 batteries.
