Too busy... that's just an excuse. This takes 15 seconds.
Automatic stuff breaks eventually...
I get about 1/2 cup out of my one 35 gallon tank.....per month if I remember to open the drain valve. Which means if I did it each day, I might get 3 drops.
Probably why that tank lasted 30 years before the pinhole's on the bottom showed up.
Incidentally, that tank is a horizontal home made one, made from a 100lb propane tank that was a rebuilt unit. It didn't have propane in it, and has never smelled like propane.
It has legs welded to it, black iron fittings welded to it for air inlet and outlet, and a platform for the motor and Quincy 210 pump welded on top of it (lays horizontal).
Has worked well all these years. Would I do it again? Based on what I know about Air Receivers NOW.......NO I would not.
So anyway, it's not worth draining it every day. And the compressor is in the back room which I sometimes don't venture into for several days. (The contactor is in the main shop area, so I don't have to go all the way out there to turn it on or off)
The new cheap Chinese auto drain valves sold on EBAY for $25-50 seem to be quite reliable. They have built in strainers to protect the seats from dirt and damage. I'll check them to make sure they work a few times a year, and when I change the oil once a year. I think they'll be fine.
