sberry
So yours rusted thru in 30 years with daily draining. Mine is 45 and drained occasionally, how long should it last? I was gone a couple times, I think it had 5 gallons in it. Several times a gallon. Some of them had a dip tube which was basically a valve with internal hose that laid on the bottom, they never would get the water out and froze off in the winter. The plus was there wasn't water in a sump which could freeze pipe.
I drain more if we are running them a lot, can go a month or more without it too. I only had to make one flare, found ready made used tubing to plumb 3 vessels to a common line thru the wall.
It was thinning from both sides.
