1/2 Cup
Member Emeritus
Bob, I do think your chain saw does need some TLC, that said isn't it nice to do it on a clean work surface.
Well done.
Well done.
Steve, apologies for my delay replying. I repaired the chainsaw without making a huge mess and was on the way out to finish the trimming when my wife told me to leave it as it was. She plans to put a plant in the "romantic" hollow branch.Bob, I do think your chain saw does need some TLC, that said isn't it nice to do it on a clean work surface.
Well done.![]()
Andy, the clean bench problem has been fixed (see above post).The chain saw gear teeth were just worn on one side, can't you TIG weld them up?
I tried, I really did but I don't have a friend that knows how to weld. I couldn't get an arc started on that gear to save my life. Used up all my argon and had to go get the tank refilled.
The vaporization of the task requirements reminds me of one of my truths: It is best to volunteer and not be needed.
That bench looks eerie.
Rod, I tried to take pictures of that side of the shop but there was so much stuff piled up in front of the door that you couldn't see the file cabinets and I had to do musical carts to get to them.Bob I don't know that we've seen this perspective of your shop area before ?
Can you put a shelf above the window near the getto blaster and maybe get some tote storage up there ? Looks like maybe 8 or 9 feet before the cabinet gets in the way in the corner.
A good bit of shop tetris though
GB
John, there are lots of places in the yard where I could put up another shed for the stuff that just needs to be dry. I'm thinking one of those Florida kite buildings (sheet metal shed) but my wife thinks I already have too much stuff and too many messes. I really hate when she's right (and I'm not).Time for a shed addition. Have a shed-building party. Looks like there are enough GJ members in your area to get it done in a day.
Bret, you're right on the size. If I had any sense I'd concentrate on my '72 Corvette and make it easier to work on. Every time I want to make progress I have to move the '87 Corvette and Cadillac out of the garage and then pull all the parts that are sitting under the car (suspension pieces, exhaust, steering column, etc. etc. etc. Work on the car for two hours and then put everything back under the car and move the cars back into the garage. A couple of shelves on that wall in the shop (and get rid of the boom box) and most of the stuff under the Vette could be out of the way.Bob I feel your frustration on shed disorganization. I think my shed is the same size as yours. I am working diligently to get all the bodywork done on the 64' so they can get bolted on the truck and clear much needed space in the shed. Once that is done I am going to completely reorganize the setup.
Yours is looking good by the way. Except you can't find anything now.
Bret
Thanks Andy. I often think I should get rid of the RAS but I do use it a lot (because it is set up).Wow! Bench looks great!
Great job on the RAS. They are space hogs.
Keep looking for flat surfaces.
Bobby, progress is slow but I am going into the shop almost every day. Sometimes it's just sorting a bucket of hardware and getting it off the bench and other times it's throwing stuff away. I am putting wheels on pieces of plywood so I can put stuff away and pull it out when needed. Baby steps are still steps.Bob good to see you back in the shop mindset. Great job.
Stewart, I can't tell you how many times my heart has skipped a beat because I thought I heard Craig, Gerard or you tapping on the shed door (it was just the rotted siding)!Bob, if you take pictures of the four walls, post them on Florida Chapter, you'll get a layout. Stop gerarding yourself without expert help.
Don, I know where you are coming from. For some reason I have an easier time keeping the garage reasonably organized but the wood shop seems to have a built-in mess-generator. Of course I don't have cool excuses for my messes like Rocket Ships and Ice Cream Parlors.Bob
I haven't dared to show my woodshop for quite a while because it is so cluttered with stuff I need to find a place for and you moving the R.A.saw off the stand gives me hope to doing the same. Thanks for the example.
Don
Gerard, I love the idea of a lift table and my back gets excited about it too. I mentioned it to my wife and she said "Where are you going to put it?" I wasn't prepared with a good answer so it didn't happen. I think a wall of lift tables would be a great start to a workshop. One for the RAS, one for the table saw (it's on another sheet metal stand), one for the 10-inch miter saw, one for the 12-inch miter saw and another for the router table. The sixth one would be reserved for lifting stuff. Remove the handle loops and line them up next to each other for a 28-inch deep, 9-foot long adjustable steel-topped workbench for $1,000 or so.Hey Bob I got a idea. Have you ever thought of using lift tables for your power equipment? Something similar to this.
My idea would be you can lower it and put equipment under a bench and then pull it out and raise it to a good working height. I’m considering something to that effect with my FIL old Dewalt radial arm saw.
I keep reading the bold words and shudder. It escapes me how someone could have too much stuff. I just can't get my arms around it. A 20 by 30 steel building with a two post Corvette lift would seem to reduce the mess factor.
Stewart, not to be political but I think Santa is bringing me a small bag of coal. I learned long ago not to wait for Father's Day, Birthday or Christmas for the present I want. I tell everyone I want tools (any kind, any price, any condition) and end up with an apron or bag of nuts. My response is to buy myself tools when I need/want/too good a deal to pass up.Sounds like a good plan. We know what Santa is bringing Bob next month.
Andy, we think alike. The building with a lift is such a logical and perfect solution. Then my wife offers to reduce the mess by giving my '72 Corvette to a needy person. We agree to disagree and I sleep without the body armor with my eyes closed.I keep reading the bold words and shudder. It escapes me how someone could have too much stuff. I just can't get my arms around it. A 20 by 30 steel building with a two post Corvette lift would seem to reduce the mess factor.
Steve, I may be making some small additions to the shed while we're re-siding it. Covered lumber storage on the outside (maybe looking like a potting bench) might be part of the plan.WooHoo, I'm in, ^^^ just say the word.
Great work with the clean up, Bob.
Keep the RAS, mine get plenty of use, a very versatile tool.
Steve![]()
Don, my current setup is a dream come true that I just need to tune up. On the other hand, if everyone showed up, how could my wife turn down a new shed. She actually kids me about the "Shed Clearance Sales" advertised on TV, recognizing the far-away look I get when they come on.Coming from you Andy that's just too funny. Good one
Bob I'm in too, a shed building party is right up my alley Just say when lol
Gerard, you forget that I'm retired and rarely leave the house. Much as I love the time we have together, I notice she spends more time feeding squirrels than feeding me. She is always happy to see me when I come in from fixing something or cleaning up my messes but I don't think she wants a whole lot more time with me looking over her shoulder (it's kinda mutual).Bob Heine not prepared with answer. I’m shocked but i can see proposing something to the wife can be tricky. Next time it get brought up just tell the wife that “ hey honey I’ve been thinking. If I get those lift tables I can get things done so much quicker and won’t be as tired. I’ll be so much more productive that we will have more quality time to spend together. Now that will be so much more important then where they are going to go now aren’t they?”
Now if that doesn’t work you can always go to plan B and sneak things in when she’s not looking. My newest technique is going months before bringing new item in and having the boys bring it over. It helps to numbers when going against her. LOL
Stewart[/B My response is to buy myself tools when I need/want/too good a deal to pass up.
Personally I don't know what they're talking about.
She gets upset when it happens but I just smile thank her for the fun job I get to do. I already showed the new bumper that's prepped and it's flat-cow-catcher brace. The fun for me is seeing if I can get the old one riveted back on.
Those are my words. I need my lawyer to check to see whether we have a copyright infringement suit here.
Scary, isn't it
I will somehow get there for the shed raising. Keep us informed. Maybe stop at Bobby's and saw some lumber as well.
Good news here, The Salvation Army and others will come and pick up your derelict vehicle and give you a form to lie to the IRS about the value of the gift.
True, a 24'x36' addition with potting bench is just a remodel.
For a long time the RAS was a bit scary to use. The blade I used was meant for a table saw and it pulled hard through the wood. Then I bought a Freud LU91R010 10-Inch 60 Tooth ATB Thin Kerf Miter Saw Blade and it's a whole different saw. Very little pull and cuts really clean.
Go with a 100 tooth next time, even less splintering. Of course that 60 tooth will last forever unless you get into foundry work and cut firebrick with it.
Sounds like the plan is coming together
A modest shed addition is just the thing for marital bliss and the fond memories of spending time together. You can hang beautiful photographs of her in your modest shed addition.
Want to plan something starting the last Saturday in March, 2018? We can arrive on Saturday and really get to work Sunday morning.
Now if that doesn’t work you can always go to plan B and sneak things in when she’s not looking. LOL
Good luck with plan B--that knife cuts both ways. Years ago, I came home during my lunch break to sneak a bandsaw into the basement. Imagine my surprise when I met The Queen at the door. She was sneaking in a few pairs of NEW SHOES!
My wife was very complimentary about the cleaned-up shop and suggested I finish the inside (T&G boards are stacked on the upper cabinets). My plan is to put 5/8" water resistant drywall behind the benches but she doesn't know about that yet. That means removing all the benches and building new ones. I have a bad case of Stevo-bench envy.
I managed to sneak three welders into the garage but I don't know about sneaking five or seven HF lift tables into the shed. Hey, if I'm going to sneak something in, maybe a half-dozen HF 44" rollers and a few meters of 2-by square steel tubing for a Steevo-benched shed.
