Best Milwaukee M18 drill choice?
MushCreek
Upstate South Carolina
My beloved Milwaukee M18 drill seems to be circling the drain. When used in the low speed setting, it slips and grinds under heavy load. I guess years of using it with large hole saws took it's toll. I need to replace it! I'm wondering what the best model is? I have a dedicated hammer drill, and a driver, so mostly it will be used to drill holes, mix paint/mortar/grout, etc. I do use it on the low a lot, as I often drill metal. What's new and improved out there?
Ole Slewfoot
Freedom, CA
Ign
Butte Peak ND
The 2604 or 2704 are reasonably powerful. —-3 would be non-hammer
Your drill is more than 5 years old? You can also see how much a “Lightning Max Repair” for your model would be at milwaukeetool.com, but it’s rarely reasonable.
Lately warranty work for me has been 2 weeks, so dunno if you could be without it for 2 weeks anyway.
Layvon
Milwaukee will fix it if you can still read the serial number
Sent from my VS988 using Tapatalk
MushCreek
No- it's more like 6-7 years old; definitely more than 5. I'd like to upgrade to a Fuel model anyway, and mine has always had a quirk where sometimes it just won't go. Swap the battery, and it's fine. I've got 5 batteries, so I started to keep track, and it's done it with all 5 batteries at one point or another. After a few minutes use, you can put the battery back on that wasn't working, and it's fine???
