joe_pinehill1
I'll admit i was careless, didnt oil the tap often enough, tried to tap too quickly. A 1/4 20 tap snapped on me. Are there tricks to remove. I imagine its hard to drill a tap.
its a tab on a kohler 12 hp engine that holds the fan shroud in place. There are many fasteners, so im not panicking. A bolt had snaped in the threads over summer. Yesterday i had time and drilled the bolt for a 1/4 tap and started to tap the hole.
The tab is aluminum, so I don't want to use heat.
Aluminum can be the worst to try to remove a broken tap from since it is so soft. The hammer and punch technique usually ruins the hole. Im not sure what you have for access or space on the bracket but maybe just drill a hole in the bracket next to it and through bolt it so it doesnt rattle. Again not sure the exact situation.
I've had success drilling one out with a titanium nitride drill bit, slow speeds, and lots of oil. It broke up into chunks. Fortunately the tap was carbide and not HSS or I may not have been so lucky.A good operator can shoot a tap out on a water jet, we do it at work fairly often. Tap generally has to be about #8 or larger to avoid enlarging the hole. A lot cheaper and faster than EDM.
This is best used for taps in through holes, but Ive seen it done on blind holes in heavier material.
Thanks for that. I've had 'em for decades. Very recommended as long as you acknowledge that the "fingers" are consumables.I have had good luck with Walton Tap Extractors
If it's unreachable, you might be able to grind it out with a small stone on a die grinder or Dremel. Would be slow going and you might go through several stones.
Tip: don't buy Harbor Freight stones. They disintegrate easily.
