FigureItOut
I needed a new jump pack to replace a five year old Schumacher Pro Series that proved itself unreliable. I don't have confidence in the lithium ion packs yet so I debated between another 660 and the new "premium" 770R. It's the same internal battery and about a $30-$40 price difference. Key stats are the same except the premium has 68" cables, versus the 46" on the 660.
I generally don't want my jump boxes to do anything but jump cars, so I don't look for the work lights, USB outlets, switches, dials, knobs and extra features, but I went with the premium and I'm glad I did. I thought I'd show you guys the differences and maybe someone who's trying to decide can benefit.
First, the 770R has two USB outlets, a 1.1A and 2.1A. I'll personally never use it. It also has an LED light on the front, it's certainly enough to light up battery terminals, and it should make it easier at night. The LED has a flashing mode for emergencies, and is bright enough to be visible to passers-by, but wouldn't blind a driver.
The premium also has a digital volt meter as opposed to analog on the 660. That's probably more likely to fail, but it's not mission critical. The biggest difference to me is the on/off switch controlling power to the cables. It's not needed really, if you're careful, but is safer if you're carrying the jump pack in your vehicle, and will prevent sparking if you connect the cables before you turn it on. On the 660, the cables are always hot, and the way they're stored, a short circuit is possible.
The height and width are almost identical, one is behind the other in each of these pics. I do kind of like the rubber boot on the bottom of the 770R.
The 770R is quite a bit bigger in depth as seen here. What I like a lot is the clamp storage seen here. It's more secure, better looking and more compact than the clamp storage on the 660.
Here's what I really don't like. The electrical connection between each side of the clamp on the 660 is a wide braided strap. On the 770, the electrical connection is just the hinge.
The 770 is heavier:
The 770 comes with a couple of useful accessories that the 660 does not come with:
Finally, a minor note that may become a huge annoyance to me, but others may not have the same issue. I have a locking extension cord in my vehicle that keeps my jump box charging full time. The female end locks securely onto every male plug I've tried it on, except the charging plug on the 770R, I'm not sure why, but it just won't lock on.
The 770 is heavier:
