My instinct from seeing those Engineer files is that it must be made by Tsubosan. Here's a look my Tsubosan's...note the style of grip:
<a data-flickr-embed="true" href="https://www.flickr.com/photos/ccassan/15451764798/in/photolist-pxqkkU-pxnDsc-qiqaam-qiwqBk-qzY8g6-dezP4R" title="J2014 Tsubosan"><img src="https://farm6.staticflickr.com/5613/15451764798_ce23974cfe_b.jpg" width="1024" height="588" alt="J2014 Tsubosan"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
The surface coating is also a specialty that they've offered for some years now. They can apply the coating in various colours. They offer theirs in silver colour (Bright-900 series).
Engineer's is well packaged. Fancy looking for sure.
edit:
A bit more information about Tsubosan....
Just one of the many file makers based in Hiroshima, Japan.
Been around making files for over 80 years.
They have over a 1000 products.
They hover around 50% of Japanese market share.
They are good at offering innovation to an otherwise mundane segment of the tool industry.
They are the most famous name in Japan, and perhaps the most well known abroad.
website: http://www.tsubosan.co.jp/index.html
I changed serpentine belt few times on my Honda Accord with K24 engine (veryThank you, Mikhail - I ask because I just bought these from Franks Tools, but KTC doesn't appear to make an 11mm in the same extra long pattern, and 11mm fasteners are common on my '96 BMW.
I bought the set of three, 8x10, 12x14, 17x19, and filled in with a 13x15.
I recently changed a belt on an Acura TSX. Prior, I just couldn't understand why anyone would need a dedicated serpentine belt tool. I'm embarrassed to say how long that belt change took. Although these are not as fit for the purpose as the serpentine belt tool, I'll get more utility out of them, and if I need more leverage for a belt tensioner, I can easily get a pipe over the double box end.
I'm hunting a 1/4 drive deep 3.5mm socket. KTC Nepros makes a 3.2mm and Koken makes a 3mm and 4mm.
Is anyone familiar of another Japanese company for this socket.
For those that have the Koken magnetic socket rails, can you confirm if they are made in Japan? Also, is it possible to mix and match both 1/4" and 3/8" on the same rail (with the correctly sized clips)?
I saw this stand at my local home center, Engineer brand.
I bought the new vice grips.
Yes, the rails accept 1/4 or 3/8 clips so you can mix and match.
They are available in approximately 8” and 12” length.
I couldn’t say if they’re actually made in Japan but they’re good quality and the magnetic base is strong!
I have an Elora standard size socket 3.5mm.Don't know of any deep 3.5mm, but Stahlwille makes a regular one.
I wouldn't say most. Just a small number of Tone tools are sourced from Taiwan (Hi-Five) ie. their "new generation" fine-tooth ratchets, bit ratchets, ratcheting screwdrivers, and ratcheting wrenches. They have some Facom tools, LockJaw locking pliers, some of their electronic torque wrenches are sourced from Eclatorq. But they have hundreds of other tools they actually produce.
Here's the company promo video in English:
<iframe width="560" height="315" src="https://www.youtube.com/embed/9i7SfuC3__s" frameborder="0" allowfullscreen></iframe>
The files arrived today. I am blown away by the attention to detail and quality. I cannot vouch for the longetivity of the black coating since it states that it is for corrosion resistance. As for sharpness, these files are much sharper than my Nichelson files. You do not need to apply as much pressure to remove material. The pouch is beautifully tanned leather with perfect stitchimg.
Tone breaker bars ....... made in Japan? Quality? Finish? Looking at a 24" 1/2" drive.
Seth
superautobacs, I believe that the non clogging is more the design of the teeth rather than the coating, but that is my opinion. So far, all of the specs that I can find point to the coating as being a corrosion inhibitor. I can tell you that I used the files yesterday on a delicate bronze casting and the files showed no sign of clogging after repeated use.
How does Tone's overall quality compare to that of KTC and Ko-ken?
As far as I understand, the teeth are set in the standard manner. The difference comes from their special plating process.
Tsubosan's coating technology was revolutionary in that it largely prevented the clogging of the file teeth, which in turn allowed the file to perform better, and keep performing for much longer
I cant read Japanese but I can tell you that the pictures from the specs on the inside of the box show a different style of teeth.
Here is a picture of the inside of the box as well as two close ups of two different files
Noid,
Pictures would be nice to see
Ratcheting wrenches, both KTC and Tone, are sourced from two different Taiwanese OEMs.
I hosted them on GJ, should be able to see them now.FastJ,
Welcome to the world of Japanese tools.
Noid,
Tone is confirmed COO Japan.
Proof attached.
Thanks for the photo uploads.
I've said this for many years and I still stand by my opinion that Tone has been, and still are deceptive about their COO information (or lack thereof).
I suppose they are "Product of Japan", but not "Made in Japan". KTC is actually transparent in this regard as they clearly state where their products are made in.
I'm happy with the few ratcheting wrenches that I have from KTC, both polished and satin chrome finishes.
Here's a photo that I took in 2010
The one in front is a KTC; back is a Crescent brand. As you can see, the finish of the chrome is great (and way more durable than Gearwrench chrome).
They are both sourced from the same Taiwanese OEM (Kabo). The older RMF series ratcheting wrenches from Tone were also sourced from the same OEM (Kabo), using the same ratcheting mechanism.
Hey guys, what's the experience like with any of the Koken non-locking flex ratchets like? I'm trying to get a sense of how floppy they are, or if they have detents in there to lock at pre-defined spots. From pics I've found, I can't really tell -- and I can't find anything on YouTube.
I really like this one 3774NL, which locks (yay), but no Quick-Release. I'd like one with Quick-Release, so they have 3774NB. Wish I could get my cake at eat it too, but...
So any experience with the non-locking ones? How's the head held in place to prevent flop?
