NewKidT/A
Originally I wanted to do heated floors in my 50X80 but I don't think I will be using it enough to justify the cost/labor to put them in, but I would still like some insulation under the slab side wall and underneath it to cut down on heat loss. From what I found most heat loss comes out the side of the slab if it is exposed.
My first attempt/thought was to cut a 4x8, 2in thick, R-10 15 psi "pink board" in half and run two feet up the wall and two on the floor but then I'm loosing 2 inches on concrete thickness on the floor which I don't want.
So my plan is to run the full board up the wall flush with the ground then add my gravel, then a thin vapor barrier on top of the gravel and go up the wall/insulation board a little bit with the vapor barrier to seal any air gap, then concrete.
As far as the out side, right now the "pink board" is exposed but I plan to lay gravel around the out side to cover that, or should I back fill with dirt then gravel?
Any advice is appreciated, this is my first build and I'm no construction expert. youtube only goes so far!
