Vintage Garages - Clearing out a Horders Time Capsule
Mintgrun
Kingston, Wa.
I believe those hefty 'pliers' are draw tongs, for pulling wire through a draw plate, to make it smaller.
I had not seen that particular design before, but a little searching brought up this image.
drivesitfar
Mint: i second that and thanks for the picture too!! :bowdown:
OT: yep sometimes i do stuff like you are doing and have to look in the mirror and say WTF, but it's kinda fun and if i had a couple hundred acres with some huge buildings on it i'd be dangerous.
best of luck with the next few phases!!
Mr_P
Tinley Park, IL
That McGraw Edison Lathe is pretty cool. It looks like it's the Saber saw variety which mounts in that hole on the far left.
O
OldeTimeEtc
Palm springs area in S. Calif
The first box out of the van......looky looky! Its interesting to note that the old crumbling newspapers these clock movements were wrapped in were dated 1968.
More to come....
ambenz
NW Chicago Suburbs
These are cool...hope you find the glass chimneys...
O
OldeTimeEtc
well been under the weather last few days so been in bed most of the time hacking up a lung. Today I felt a might better so I got a box out to go thru late this evening and heres some more finds.
Mr_P
Tinley Park, IL
I recently seen one of those handheld welders turned into a steampunk lamp. kinda cool. Any markings on that hammerhead?
O
OldeTimeEtc
Here's an unusual find.....a vintage "new old stock" Stanley shaper table accessory model 43A. Pictured is a grap out of a 1944 catalog which is not the same model but simular enough. I'm guessing this accessory was made in the 60's. The catalog calls it a "straight guide with safety guard"
O
OldeTimeEtc
Another unusual tool find.............new old stock "Anglevel" in original box with folded user instructions in the bottom of the box.
skruft
For the clock related stuff, you could speak with your local chapter of National Association of Watch and Clock Collectors; there is a website.
O
OldeTimeEtc
Going thru more boxes.....lots of tool finds and possibly some gold and I already know how to test precious metals.
jakemac
New England
How does that bottle cutter work?
It heats a bare wire and essentially melts it's way through the glass.
I remember them being a thing in the early 70's craft movement when I was a kid.
(45yrs later any time I see a macramé Owl or plant hanger, I still want to cut myself :willy_nil )
O
OldeTimeEtc
...and the finds keep on coming.....
O
OldeTimeEtc
On a side note its interesting that all the paperwork like letters and jewelers order receipts found in the latest box were all dated 1937-1940
Old Man Roger
Palm Coast Florida
I always thought they heated the glass, then you hit it with cold water?
O
OldeTimeEtc
More stuff....
O
OldeTimeEtc
More more stuff....
O
OldeTimeEtc
Here's a challenge for some bright lad ....... trying to figure out what use this precision tool is for. I think it might be for grinding gravers. There are no makers marks. The cylinder part rotates and has degree graduations from 90 to 0 degrees in both directions. Then there is a table that slides back and forth using the small wheel with a T slot that cut into it so something may mount to it. ......the lines look like they work like a vernier caliper. Had to take it apart and clean up the rust. Its a well made little tool.
jimreed2160
Tallahassee FL
Dunno on the bottle cutter. I doubt the thing gets hot enough to melt the glass. I'll bet you heat the glass with the wire and then plunge the bottle into cold water so it will fracture at the heat line.
Yeah, I did that with a string, lighter fluid and a wine bottle when I was in college during the 1960s. One of my buddies needed a blues guitar slide so he could play like the Allman brothers. And it helps to have some aluminum oxide sandpaper to soften up the sharp edges.
jask
Gods Country, B.C.
lots of good stuff there!... I almost got ahead of myself a few pages back when I recognized those draw tongs... if you want to see them in action google up "jewelers drawbench" and you might well find the rest of the bench in all the other ephemera and treasure. I think I saw a jewelers or watchmakers bench peeking out from behind a gerry can back there.. did you find any drawplates?
drivesitfar
OLD TIME: keep posting up pictures as you have time and i'll try to find something maybe i might know something about if you need help. cool stuff that is for certain.
so were you or are you a WATCHMAKER since you said you were a member?
Jake: I make ice tea in old glass gallon pickle jars and maybe 3 times i didn't wait long enough to let the jar cool after emptying it before pouring boiling water in it to make more tea and CLINK. yep the bottom of the jar just broke all the way around about 1/4 inch above the base. needless to say the half gallon of new hot tea didn't stay put in the glass jug long after that.
I didn't know there was tool that could do that. thanks for the tip
O
OldeTimeEtc
Emptied a couple boxes today.....some vintage travel alarms and a few tools including a vintage Carter/Stanley Router with original Owners Manuel and a Mido Waterproof tester
tym
Nice! I've been looking for a nice Waltham travel clock to replace the one I stupidly sold many years back.
O
OldeTimeEtc
I think the Waltham Clock you speak of is more similar to this example. It uses a 36 size pocketwatch 8day movement. These were commonly used in early car dashes too.
Bigwheels
Idaho
Estate sales have become my favorite passtime especially the old farm and ranch sales out here in the west. Walking into a barn or an old shop is like walking into a candy store as a kid. Congrats on your endeavors.
