Right way to make a Y with stranded wire?
mixerfixer
MD
Didn't read the whole post. Not sure if this was mentioned before or not.
MSC Direct. You can get yellow heat shrink **** connectors. They have a blue line on 1 side.The blue line takes 1) 14 gauge wire. The other side takes 2) 14 gauge wires. Crimp it, heat it, seal it. We use them all the time on concrete mixers. Works really well and quick and easy.
Leaflessshadetree
Don't ask.
The thing with a Y splice is the leading wire should be a larger gauge wire than the exiting wires.
In many cases it works better to insert a short piece of wire in the single side of a crimp splice to get the right size for the crimp sleeve and heat shrink.
That piece should be short enough that the heat shrink fully covers it.
bas157
Near Philly
Found this today on part of a harness I pulled from a yard off an F-250
one in, three out. Not sure if they are soldered under the heatshrink or how they are attached.
SantaAna12
Nice. Who makes them?
