Uncommon use for a two post lift
Kjbakke2
Madison Wi
at first glance it looked like your lift was in your living room
i like your garage ron......especailly that burgundy snappy :drool:
NUTTSGT
Northern Central Ohio
When I had the inground lift in my garage, I'd roll my used oil barrel on it, raise it up, back my truck to the lift and load it off the lift.
back2class
Nice shop. I don't typicaly like "pretty" garages buy yours just looks right! A nice place to work.
kvom
*******, GA
mechamunch
I also thought the lift was in the living room. And I thought to myself, "Daaaaaaang, if he's got a wife or a live-in girlfriend, he's the luckiest man ever."
Deer Run
VT
Would you post some more photos of your garage / living room? If you have them. Looks like you have a really nice set up.
srmofo
SW ohio
when we're slow at the shop, i put a bar across it and work out. i can get most of my upper body done before i even hit the gym. pull ups and dips are the norm. plus if you have a lift where the legs dont lock it helps you work on form cause the legs can move.
ive also lifted my mowers (61 inch yazoo-kee)with em to change the blades and clean the decks
R
ron in sc
Charleston, SC
I'll take some photos this weekend and put them up. Garage is now 99% done. About all that's left is to put up large screen tv and install track lighting along the soffits on both side of garage.
fordcragar
Yakima Wa.
I use mine to lift things in and out of my truck all of the time.
I needed to lift vertically, a 14" square piece of 1/2" wall tubing that was 8' long and set it in a base; and used the lift. The tube weighed over 700 lbs. That was an interesting task.
