New to me compressor
isuhunter
My brother in law gifted me this compressor in his move. Sounds like a few leaks coming from fittings and regulator.
Thinking about replacing the regulator setup. Any suggestions?
Anything else you’d recommend doing?
JohnDeere1
Kentucky
Made in usa that's good the one I bought is a craftsman pro 25 gallon made by devilbiss says assembled in usa of global components lol it also has leaks in the line coming from pump into tank and recently the drain valve started leaking keeps dripping water goes to 150psi and the regulator don't work so my air tools really scream worries me about blowing seals in the tools running them that high.
paker
Is it practical (time and cost) to replace the direct drive pump with a belt drive pump?
redmondjp
Redmond, WA
Short answer: no.
If you want to step up a bit, look for a 20-30 gallon two-cylinder splash-lubricated compressor. You can find them used for $50-150. There are endless threads on this forum regarding compressors - grab your favorite beverage and start reading.
If that one works, keep the tank drained and use it. Don't expect it to do continuous-duty (where you are using a high-flow air tool for several minutes at a time) however - that will shorten its life dramatically. But for light-duty use, it will be fine.
Citation
Indy
User settings soapy water to find the leaks odds are most can be fixed by disassembly, cleaning and resealing.
