Matt's projects
F
Fretters
South Yorkshire, England
I didn't take this one apart, so I have to figure that one out as I go. :D It should be all fairly straight forward though. That pile of bits was as I received it. :D
F
Fretters
Not specifically old tool related, (although it is a rack for), but in the process of having yet another shift round in the workshop, and decided to try and make my hammer rack a bit less obtrusive. The old one was a floor to ceiling jobbie, so always occupied either some floor else wall space. This one I've strung between the wall and front leg of another bench/storage area I've made. Just a couple of pieces of 3"x1" planed, one screwed either side of a 1-3/4" riser, to provide the gap for the handles. Approx. 4' long.
guimage
F
Fretters
The bed has been derusted/depainted. Popped a coat of linseed oil on the inside of the bed casting yesterday, and then waxed the outside today.
guimage
guimage
Took this photo just before I finished applying the wax. Left a little strip undone for the photo, which shows the difference more clearly between the bare and waxed cast.
guimage
Once it's had a day or two to cure somewhat, it'll be getting a quick buff.
drivesitfar
Fretters: nicely done. is that the wax mix you mentioned on the vise repair 101 thread or did you add and subtract a few things. i love when you post your old cast iron stuff naked or burgundy or even that green you do on a few things. :thumbup:
F
Fretters
Aye, it's that same mix which I used on that vice and stand. No changes. I'm interested to see how it'll cope with the types of fluid machinery will be seeing. Oil, paraffin/kerosene, possibly some cutting fluid etc.
The remaining Brunswick Green is reserved for the 5". After that last faux pas with the batches being completely different tones, I'm not taking the risk of running out again before I complete that. Already had to restrip and repaint most of it due to that. :D
F
Fretters
Finally getting close to the point where I'll be starting to reassemble that lathe. Most of the main parts are cleaned, derusted, coated and ready.
guimage
guimage
guimage
guimage
guimage
Just need to finish the fun part first though, before any reassembly can start. These are currently in the vat.
guimage
Going through those and wirebrushing each one as I take it out will be a time consuming process, to put it mildly. :D
Craptain
Tampa Bay FL
Glad to see you back in your own thread.
I wondered if we would ever see the lathe done.
Sent from my LG-D801 using Tapatalk
drivesitfar
Fretters: not many if any know how to show 100+ year old parts that look new in the box. WELL DONE SIR :bowdown:
Also best of luck with the Fretter's manual you hopefully memorized or scribbled down so you can put that gem back together.
I agree with Craptain it's good to have you back.
F
Fretters
Cheers chaps. :) Aye, I have been a bit remiss with updates.
Some of it I've disassembled myself, but it was mostly dismantled when I got it. Something of a jigsaw puzzle for reassembly, this one. It's not too complex, however, so apart from just the odd little bit, it's fairly easy to figure where most bits go.
drivesitfar
FRETTERS: I for one MISS U. any updates in your world to chat about? even a smoke signal to say you are alive and well and maybe a little wet will do.
cheers!!
F
Fretters
Apologies for the late response to that post Dif; I'd not seen it 'til just now.
No progress on the lathe front recently, but have mounted the Baldor grinder on a stand so I can do some drill bit sharpening in comfort. It's a Heath Robinson affair, but does the job. Reappropriated that stand I made for painting on for it. No tool rests for it either, so excuse the replacements. :) I've grown quite fond of that wooden block now. :D It's just the right size for freehand sharpening.
guimage
guimage
Btw, yes, my shed is usually such a **** tip, floor wise. :D
drivesitfar
Fretters: I just saw you posted on your thread again. i love the baldor stand and i know you won't burn down the place with the cool wood surround to keep some of the dust and debris inside it.
sure i know about FSD (flat surface disease) and that includes floors, shelves as well as benches and counters.
i just found a way to check my threads I'm interested in that you may already know about or maybe not. see the black bar with links and the first on that says USER CP? well i click on that and it shows me if anybody has been posting on threads i post on. i can't believe i have almost 4000 threads i've posted on, but i do like this place as you well know and i learn something everyday.
i do miss your posts so i know you are busy with work and teenagers, but if you get time to interject some wisdom or humor please do.
cheers
F
Fretters
It's like a compulsion to dump stuff on it when an empty space appears, isn't it. :D
Finished the stand off today. I'm not going to faff with it any more now; Honest. :D
guimage
drivesitfar
Fretters: i hear you on the FSD (flat surface disease) and Twertsy even admits to FSS (flat surface syndrome) that can't be cured, but i think he has more stuff than any 5 of us put together at the moment and he needs to start a museum.
speaking of cool stuff i looked closer at your grinder's tool rests and do tell what are they made of and how do they work?
you might want to post your little gem over on the vintage grinders thread if you haven't already.
keep up the good fight and just know that if you need to know anything if you can't find it on GJ just ask your teenagers cause you know teenagers KNOW EVERYTHING. don't they?
I have a thread called DRIVESITFAR'S finds and I picked up pair of lathe or old machine legs you might like to tell me what they came off of when i get time to post pictures. thanks in advance
Cheers Mate!!
F
Fretters
The left toolrest is just a block of pine. The righthand one is a bellhousing from an old Van Dorn grinder with a piece of MDF on top. (That was going to be a restoration, but the base is shot and the wiring is dubious, so I've retasked one of its parts). Hammered a chunk of lead, (an old sash weight), into the end of that bellhousing to give something to bolt through.
The little copper dipping pot is a piece of 28mm tube with a 2p coin soldered in the bottom. Flared the top with the outer face of a Priory wad punch.
Regarding teenagers, don't they just. :D I banned the eldest from using the phrase: "I know". It's like I told him, if he knows, then why's he asking. :D
drivesitfar
Fretters: anything new going on in the SHED now that it's maybe stopped raining in your part of the world?
or has it?
yep we'll be empty nesters for the first time in our 30+ years together here so not sure we'll know what to do now that all the NO IT ALLS are not living with us.
i hope we survive. :D
F
Fretters
Thought I'd best update this thread. :D Changed jobs a couple of months ago, so finally getting more workshop time now. Bought another Drummond, (Myford produced. They took over production of these machines in WWII), a few months ago:
guimage
as an interim runner until I got one of the others up & running, but found someone had stuffed the bearings with grease rather than using oil, so it needed stripping & cleaning. So, thought sod it, I'll use it for parts to get the Admiralty machine up & running, so that one is currently a work in progress, again. :D
guimage
F
Fretters
This is going to, hopefully, be the bed part of a stand for it.
guimage
It's a surface plate which has seen welding use, so accuracy for its intended purpose is shot. Good enough to make a sound bed for a lathe though.
F
Fretters
The threads on the rear end of the mandrel were buggered due to the grub screws being tightened down without their brass slug being inplace:
guimage
so after a few failed attempts at finding a needle file with a fine enough edge to sort them, I ended up resorting to the thread file, (or rasp, as I prefer to term them :D).
guimage
F
Fretters
Had to file down one of the bearing wedges to fit the rear bearing. What a tedious job that was. Due to the size and shape, very little could be done with it held in a vice, so my fingertips did most of the holding. :D Left one is the one I had to reshape.
guimage
guimage
This is the purpose of the wedge. It's used to spread the bearing to lock it into the housing. The oiler bolt screws down into it.
guimage
Bearings inplace on the headstock. The castellated nuts look shiny because I had to file & Brasso them to get them looking presentable. Apes with Mole grips have no regard for cosmetic considerations. :D
guimage
Also had a session the other week cleaning & derusting all of the Drummond changewheels. Over 60 in total, so that took some time. :D Here's some of them.
guimage
F
Fretters
Also have the bed of this lathe in the vat currently too. More for removing the layers of paint than derusting.
guimage
That's the first Drummond lathe I bought. Approx. 1907 that was produced.
Craptain
Tampa Bay FL
Nice to see you still alive. I have been wondering where you were and I guess working is the answer.
I have been dealing with hardened grease in my lathe too. The change wheels were caked in it to the point that they couldn't be correctly adjusted, resulting in a stripped gear. I think it might have been crashed as well.
Sent from my SM-G930T using Tapatalk
drivesitfar
Fretters: nice to see you posting on your thread and showing us some of the ways a guy can use hand tools and fix things.
One of these days i'll find a lathe that is decent quality and not priced to the moon and buy it hopefully with some extra tooling, but until then i'll keep watching and learning how to fix/repair and use on here on GJ.
WOW that Parkinson swivel jaw is AWESOME. i know it's maybe too big for your small shop, but it looks amazing on that cool stand you found. is it a quick release and did you use the linseed oil, turpentine, beeswax and japan dryer mix for the finish or do tell?
cheers
PS after my last post on here i thought i scared you away since i've finally got my 5 kids off and living at their own places and you having teenagers. well my daughter had an injury and needed to move back in for 4 months or so and she finally moved back in with her husband a few weeks ago so we'll try this empty nest thing again. sure is quiet around here and something for you to look forward too!
F
Fretters
No Japan driers in my mix DIF, but yes, that's the mix which both the lathe & the vice are finished with. It is quick release.
Aye, it was just work which was interfering with my shed & forum time. Was working away a lot, silly hours etc., so personal time was almost nonexistent. Dropped on this job which just has me working a few hours a day locally, so much better now, plus the new job is stress free. The previous job was a pain in the ****, for multiple reasons. Money ain't everything, when all's said & done.
drivesitfar
Fretters: yep QUALITY OF LIFE is definitely worth a lot so happy to hear you maybe found a good solution. :beer:
will that Parkinson and it's stand maybe fit in a suitcase if i stop in for a visit and it WOULD give you a little more shop space? :evil:
F
Fretters
Old grease can turn a simple job into one that's a pain, can't it.
You wish. :D It might fit, but the weight would screw your baggage allowance. :D
Definitely an improvement, job wise. Never thought I'd hear myself say this, but now I'm working surrounded by women rather than working with blokes, there's far less bitching, whining & pettiness to contend with. :D
drivesitfar
Fretters: so i guess i'll have to bring 3 suitcases? :evil:
sounds like those gals MULTY TASK instead of find ways to NOT DO SOMETHING .
not sure exactly what your day job is, but if you are as good at it as you are with the stuff you spiff up and fix in your shop your employer must be a happy camper to have you.
nice job spiffing up that Parkinson!!
how many Record vices with quick releases have you taken apart. do you have any pictures or methods to share cause as you say with the end of the dynamic being enclosed it looks like i'll have to take out the vise nut to get it out and then I bet the spring and pin is a PITA to get out?
cheers
F
Fretters
Record's are ones which I rarely touch, but heard the standard, larger mechanics vices have enclosed slides from others.
Job wise, I'm a caretaker/handyman now. Suits me down to the ground. :) Good hours & stress free, plus practically just a stone's throw from home, so couldn't ask for more. In my last job, the hassle I had to deal with & sort just wasn't worth the money. I think Gert preferred it when I was working long hours & away though. :D
Craptain
Tampa Bay FL
Keep Gert happy and spend more time in the shed. [emoji106]
drivesitfar
Fretters: remind me (us) who Gert is? i'm assuming your bride?
your new job sounds a LOT BETTER cause as you say money isn't everything and you'd probably live longer and make up the difference in a good attitude and come across better deals cause you'd feel like searching again. sometimes life can really drag you down so keep doing the best you can to avoid feeling that way.
take care
drivesitfar
Fretters: that clears that up. no way i'm calling my bride my SWMBO or whatever some of the older guys call there's cause i'm sure i'd have to sleep in the car if i did. she's only 5'9 and 140 pounds and i ain't messing with her or would I cause she's like a BOBCAT, but she has BENEFITS to be sure.
carry on big guy and show us some more TOOL **** when you are able to get some time to post up more.
cheers
F
Fretters
Might as well give them a valid excuse, occasionally, for complaining. :evil:
Headstock rebuilt. Got it all together once, then realised it needed another washer by the thrust bearing, so had to strip and redo it.
guimage
drivesitfar
Fretters: sorry you had to take it apart and put it back together cause you forgot to put in a part, but it looks awful PURDY now.
i try not to razz, irritate or bother my bride much cause she makes most of my meals. there are those other benefits that we won't talk about that she seems to want almost more than i do these days.
cheers and keep up the good tool **** pictures!!
F
Fretters
Didn't forget to put one in. :D It was just a case of what was on there originally, in the pile of bits, wasn't enough to give clearance from the bronze nut. Had to add an extra spacer in there to provide clearance.
Workshop is currently looking like a bomb site, as I'm rearranging, trying to make space for a bench for it.
drivesitfar
Matt: i'm hoping to see you get a little (or a lot) more time in the shed in 2018 cause always love your projects and of course your posts almost always make me smile too.
cheers
MERRY CHRISTMAS!!
