78 f250 cummins build
phor53
Damn...such a nice build and progress so far. I wish I could have the time to finish my Mini cooper lolz
Sent from my LG-TP450 using Tapatalk
Z
zkdiesel
chicagoland cornfields
Love the progress.. and the Ford Gray.. Plus the classic Cummins C on the air intake "tower" just ahead of the air intake heater... Great to see this coming back to magical life.....
Thanks!
This was actually a non grid heater truck and remains as such currently as it doesn’t have plans to be run in cold weather
Dennis Leigh Henry
South Central, IN USA
Interesting.. When I joined CMI in '91, that was one bit of "technology" the guys at the MidRange Tech Center said made our engine different than the others. I'll have to ask one of the old timers if they remember when it was added, etc.
Z
zkdiesel
It was an option on this ford chassis engine that this one wasn’t speced with. Actually have a grid heater off a freight liner of the era but choosed not to use it for cleaner/less wiring/ less to go wrong. Realistically won’t run below 40* and has a block heater if need be
Z
zkdiesel
Truck did a stomp around the yard in almost fully finished form. Needs temp gauge adjusted and fuel gauge wired, and some engine tuning, but roads wet and salty so it only saw backyard and field pulls in the snow
Next load of engines for future projects
Z
zkdiesel
Known good zf was kinda fawked, so this week I yanked it and tore it down and made my parts orders. Synchros, sliders, keys and 2nd gear on main shaft got replaced, now it shifts like a dream. I’ve had a few zf6 apart and must say they are easier to repair than the zf5 based on case design for loading the main shaft and countershaft with rails into the case half
Z
zkdiesel
Weather got nice, been out making pulls setting my fuel screws, and star wheel and adjusting the plate to get it running with just a haze of smoke at wot from a start. Runs well now. Dmi bumper replaced the double tube
PhantomEB
Medicine Hat, AB, Canuckistan
Subscribed as I need to read this whole thread from the start. Hoping to pick up a 97 f250 ex cab long box, 460ed 2wd to convert to 12v 4wd with a 60 in the front.
Thing is damn near rust free so it’s a great start even if it’s white.
zmotorsports
Northern Utah
I've always liked that style of bumper as well. So much so in fact, that on my 1988 Ford F250 that I converted into a dually (yes I did own a Ford at one time but I don't want to talk about it). I fabricated my own rear bumper and fashioned it after the Westin line of tapered bumpers like that. In mine, I incorporated the 2" receiver tube into the bumper that tied into a framework under the bed and also cut in two slots for back up lights that were hooked to a toggle switch in the cab.
I loved that bumper, wish I would have kept it (truck not so much).:lol:
Z
zkdiesel
Like that style bumper, wish I could have kept the adjustable swinging spring hitch, byt the rear mount 40 gallon tank kinda was limiting so it’s just a shell with a
Class 3 receiver under it
Wanted a chrome one and the cost of making one from scratch and having it then chromed
Far outweighed a nice used one
Got pictures of yours?
Z
zkdiesel
Drove great all year, **** weather hit this weekend in Chicago so it got parked now for the year
No problems all year other than adding an air powered cummins exhaust brake at the end of the downpipe that i salvaged off an 8.3. Controlling it using high/low selector on the ten speed shifter handle
In a week or two once I get all three case skidsteers cleared from the shop with the pre snow plow preps it’s gettif out in the corner and stripped down off all accessories, mirrors, door panels, fenderwells, bumpers, lights and grill shell and then getting rollbacked to paint shop.
Mike.ASC
East coast
Well done sir! Have I seen your JD tractor somewhere else? I'm sure a lot of people on this site would find more info/details on the JD very interesting.
C_F
Utah...SNOW BLOWS!
That's great that you have had no problems with it, sounds like you did it all right! :) What color are you going to paint it?
Z
zkdiesel
Same color, just redid with nice gaps
Need to get the skidsteers out on snow duty to clear some shop space
Strouty
Southern Maine
I finally dug out the F700, going to try and start working on it this winter. Need to tear off the rack, lift gate, and back body. I think I want to use or make a dually bed, also thinking of using MRAP axles.
lugnut71
Wyoming
That crew is awesome! what about some coil over suspension on some 1 ton axles with like 40" tires ? shorten wheel base and put fleetside box on it ?
Z
zkdiesel
Stripped down
iowa4x4dieselman
Awesome build so far! any updates? I am planning a similar swap but thinking of going zf6 in my 1979. Keep up the good work :thumbup:
Z
zkdiesel
Paint guy has been slacking but cost is way down due to trading work. Show quality straightness due back to me soon
Also have extra 24 valve if needed now
TimeWarpF100
not here
Very cool!
Always liked the 73-79 Trucks and have owned many but the 78-79's are my favorite.
Z
zkdiesel
Some parts back but no truck yet sadly
So who says I need pictures of me making the 29 year old blonde reassemble her truck?
