Torque wrench range for lug nuts
Jaguar Fan
Park City for Ski Season; Las Vegas for Poker Seas
I'm looking for advice on a torque wrench for lug nuts. Currently I have 3 vehicles with the following torque specs:
* 135 ft-lbs
* 105 ft-lbs
* 80 ft-lbs
I'm looking at Tekton wrenches. I can get one with a 10-150 range, or one with a 25-250 range.
What do you suggest for lug nuts (mainly)? Or should I go with a different brand?
Thanks for any real-world advice.
Tonyuk
Scotland
ItsNemo
Canada
Go with the 25-250ft-lb one, torque wrenches are more accurate in the middle of their torque range. As well, the higher torque ones usually have a longer handle making it easier to use.
jpinca
NorCal
+1....have it and love it. Simple cheap and nothing fancy needed for lug nuts.
Ditto. These perpetually have a coupon or are on sale with 20% off coupon.
openwheelracing88
Love the Tekton 1/2. Great quality and accurate. Got it for $24 after coupon at Lowes.
I also use a Kobalt 3/8 for suspension and other small jobs. Slightly better built than Tekton, highly recommend. Got this one for $33 after coupon.
rlitman
Long Island
+1 That's the torque range you want for lug nuts on cars and light trucks.
Siteman25
I have one of the 1/4" tekton and it's pretty good, better I think than the harbor freight, for $20 more I would get the tekton in 25-250 range, as it puts your torques closer to the center of the range and about a 6 inch longer handle.
JohnDeere1
Kentucky
I have a Wright made by CDI I paid 50 bucks for it used but it's in New condition and bought a Craftsman made in USA off CL for $20 Lee in package both are 1/2 and work great I only use them for lug nuts. Look on eBay for a used CDI they make them for Cornwell and Wright as well as snap on and themselves should get one for $50 I bought 2 and sold one to my MIL..
AndeiH
texas
another vote for a 25-250 ft-lb torque wrench. i use mine mainly for lugnuts but a couple of weeks ago i had to torque a couple of bolts on my car to 180 ft-lbs.
joe_padavano
Northern VA
The reality is, it doesn't matter. First, lug nuts will hold the wheels on the vehicle under a fairly wide range of torques, second, the variables of friction, rust, lube (or not), etc, etc, mean that the actual clamping force you generate will vary widely for a given torque setting. Getting the 25-250 because it's more accurate in the middle of the range is unnecessary for this application; you'll just be fooling yourself if you think the clamping force on the lugs is that much more precise as a result.
My answer would be different if you were building race engines or the space shuttle, but if your primary use is tightening lug nuts, don't lose a lot of sleep over this.
guy48065
Calibration Lab
If the accuracy spec is the +/-3% typical of clickers, that's 3% of the READING--meaning the allowable error is smaller at lower settings. If your wrench is on the high side of spec your limit at 50 Ft-Lbs is 51.5, while the limit at 250 is 257.5.
And for those of you who believe the myth that clickers are unreliable, consider how accurate and repeatable it MUST be to be within 1.5# 3 times in a row.
wkndwarrior29
NorthEast
+1 on this.
Also consider that you should not use a torque wrench in the first or last 10% of it's band... So if you are looking to torque to 140lbs most industries would not allow you to use a wrench certified to 150lbs.
Considering you are torquing lugs I will assume that you are doing other maintenance on your vehicles too. You could eventually need multiple torque wrenches... The most I can recall torquing to on my vehicles is 145 lbs for a hub nut. I would suggest something that covers the high end of the range now for your specific use and understand that you may want/need a 15-85 lb wrench in the future for other jobs...
I have Craftsman digitork wrenches, they serve a purpose but a regret that I have is selling a snap on flex head wrench that I had... Mine are bulkier and sometimes I end up getting things good and tight because I can't get the wrench where I need it.
Sent from my XT1650 using Tapatalk
visionguru
Chicago
If torquing down lug nuts will be the only use, I'd recommend a digital adapter, like mine:
You can actually see exact the torque you put on.
If you like mechanical, Harbor Freight is pretty cheap and good. Tekton is nothing special and probably made in the same factory.
Coach James
Sandhills of North Carolina
Do you need to keep a dwarf spotter around to watch that needle move just inches off the ground? :D
Ha! First time I put it on a lug, I thought "How the heck do I read this?". Then the light bulb came on and I thought to keep it as close to vertical as possible. Sometimes simple things aren't so simple for me.
Coach
artbuc
....Tekton is nothing special and probably made in the same factory.
What is the basis for this assertion? Have you disassembled, inspected and done comparative testing? Are you just guessing about the factory location?
WhiffySpark
You guys worry about torquing a drain plug but you’re willing to put the cheapest Chinese torque wrenches on your lug nuts?
gdocktor3
Connecticut
MIL as in mother in law??
