moparfreak
So I am in the latter stages of planning out my compressed air system to plumb up to my compressor. For a couple years now I've lived with a simple system dragging a hose right out of the compressor to the various areas of the shop, and now I'd like to get it installed onto the walls and accessible to all the areas of the shop conveniently.
The biggest thing I've got as a question mark is figuring out what type of compressed air plumbing/hardware I should include, and where. There's coalescing filters, dryers, lubricators, oil removers, water removers, regulators, gauges, etc. It's where most of the money can get spent on these systems. What type of stuff is best used where?
As far as my plan goes, I plan to have a few different types of drops:
- General use workbench drops for general work. Expect this type of use to be nailers, blow guns, die grinders, zip saw, general small hand work. These drops would probably include a coiled hose and a relatively low-buck pressure regulator w/ gauge such as this one:
https://www.menards.com/main/tools-...6-c-12917.htm?tid=1084071434130140913&ipos=50
- Automotive bay drop, this would use more of the higher flow type tools used on car restoration & metal work, so impact guns, air ratchets, air hammers, grinders, sanders. I'm thinking maybe an oiler would be good for this drop, as those are the type of tools that need consistent lubricaton?
- Drop for small sand blasting cabinet, and also light painting such as airbrushes or HVLP. I'm thinking this is where a dryer and filter would be best, such as this one?
http://www.eastwood.com/rockwood-3-8-npt-2-stage-air-filter-dryer-system.html
I could put the filter / dryer in at the beginning near the compressor but then moisture that builds in the lines wouldn't be treated. Just not sure what is best practice here.
