Extended table saw fence and router table
theoldwizard1
SE MI
Is this an aftermarket fence/router table system ? If so, who make it.
jtool
I think it's part of the Ryobi BT3000 or BT3100 table saw. I believe it has been discontinued.
Firstram
Not sure who makes your fence, but if you're looking for a new one I sure hope you can find one with a built in heater!
T
theoldwizard1
SE MI
Wow, those pictures look like a pre accident photo shoot.
Yup, Ryobi. Those BT’s have a following.
The operator is a well qualified, experienced carpenter working outside in the snow, so I do not question any of safety gear.
I looked up some images of those Ryobi saws. The look similar but do not have the yellow plastic end caps.
PCustoms
VT
Lol, whenever I see someone wearing gloves while operating rotating machinery my sphincter puckers up....:beer:
That and the board doesnt look flat against the table, just waiting to bind.
Never saw the need for a contractor saw like these, if I can't cut it close enough with the skillsaw then it's probably a finished piece and every portable table saw I have used can't make a finished cut worth a damn anyway.
T
theoldwizard1
SE MI
Google search for "extended table saw fence" has not come up with a good match so ...
I have been shopping on and off for an older (late 70' - early 90's) Craftsman 10" table saw. Cast iron table extensions on both side, front mounted, belt driven motor. But I really want and extended fence system wuth the capability to mount a router and use the work surface as a router table.
So how about some "cost effective" solutions
(which leaves out Biesemeyer). Remember this is going one a 20-30 year old second hand saw that I will likely pay $100-$150 for. A fence that can be adjusted truly PARALLEL to the blade, and will stay that way, is key !
PCustoms
VT
80/20 setup using parts from fleabay?
Seems that this is an area that is either cheap (in cost and quality) or $$. The biggest thing I always looked for was stiffness and how tight/smooth the fence adjusted
I haven't looked into replacement fences in a few years since I lucked into my cabinet saw on CL. 80" table and Bessemer fence FTW.
