Show your new tool arrivals
Hytekrednek
I have seen a lot of posts on line about them matching at different stores. I have two Lowes stores close to me. I went to the first and the pretty much laughed me out of the store. The second said they would, but only on tools and like the coupon says "only one item" . I was saving up and had the cash!
You never know unless you ask. Thanks. I will use this tip in the future if the store near me will accept others coupons.
tweety420
A few of the new toys I had been saving up for. :bounce:
Smokeshow69
Picked up a cabelas work jacket today on their 40% off sale! Paid $60 which works for me! I have been needing a work jacket. Extra large tall which is not always an easy size to find !
ladrones
NM
Trying to beat the 1st of the year.
This air hose was 20.00 so I figured I will give it a try. Not sure if it’s gonna be any good.
Added a couple of wire strippers as well.
Locker537
Massachusetts
My local sears hometown still has a a couple dozen screwdrivers and scratch awls in a box for $1.88 so I grabbed a few for gifts, along with one of the last usa made wrenches in the store. Ball end torx to try out from a local bolt supplier73a340eaa98ac705e3defe7904186459.jpg
Sent from my SM-T700 using Tapatalk
I wish I could find those Craftsman Professional screwdrivers and awls. I have a 6 piece set of the screwdrivers and love em. My parents got me them ~7 years ago.
Stooge
South Shore, MA
Locker537
Massachusetts
wvhillbillie
West Virginia
SK order: needle point 6in slip joints, wrench was sent error but was told to keep and my pipe plug socket is on its way and some torx bits to try.
Wiha: 35 pc set $32, really been needing this.
Sears: 12 ton bottle jack $16
Amazon WH: Eclipse chain pliers $6
Amazon: Astro molding removal kit and no mar scraper set.
ladrones
NM
Got these in today.
Strouty
Southern Maine
New Snap On SBF80A, wish it was a comfort grip, but not available yet. At least in the 1/2” drive it doesn’t feel awkward in my hand. Only has USA on handle, my driver told me if I machine it down to fit a comfort grip, he will still warranty it.
02Xterra
Lynchburg, Va
Nice! I need to pick one of those up when the comfort grip comes out.
Small order from HJE today for my brother-in-law, he doesn't have many tools, so what better Christmas gift than good tools! 2nd pic is the rest of the stuff for now56998593426a372678aff432868bab3c.jpgcc1cae43995a2728e3143af56f4743a1.jpg
Sent from my HTC6435LVW using Tapatalk
IMStuner
90zcar
New hammer, decided to give the Estwing Ultra series a try. Made here in the USA.
Just got me a 24oz ball peen from estwing. I like it way better than my snap on dead blow ball peen.
Looks like a nice set, how do you feel about having a few sizes doubled up?
Very nice indeed. I have this set as well.
The doubling up on sizes is important because often a nut and bolt will have the same size. This allows you to use one wrench to hold the bolt head and the other to turn the nut.
You may also notice that these Genius wrenches are thought out well for the sizes. Instead of the standard 10-11, 12-13, 14-15, etc wrench sizes. They have the appropriate sizes that you will need on the one wrench. 10-12, 12-14, 14-17, 17-19 etc. This allows for the least amount of tools to be taken under the vehicle while still having double of each. With this example you can see that with 4 wrenches you can do almost all of the work underneath the vehicle. The 10 is not doubled because it is very rare that a bolt head of 10mm will have a nut with 10mm size.
KTC, Genius, Asahi, and a number of other brands have sizes like this. The tools are designed with consideration for their use. Instead of the standard 1, 2, 3, 4 increases which are not thought out to be useful.
IMStuner
KoolGrandWizardLuke was right on the money.
You are absolutely correct and that why I double up on a Snap-On set. I purchase these since I gave one of the full Snap-On set to my father. The fit and finish looks really nice but I wish the handle was rounded off more. For 100 bucks these should be worth every penny. I didn’t fine a angle head set and if they do make one I’ll purchase it.
4 FN 27
Minnesnowta
Finally after a little delay we got our new 8K Fiber Laser up and running.
During the install they found the Fiber Cable had been damaged. They shipped in a new Cable, not once but twice to find they were damaged in transit. The 3rd one worked...lost a week of production.
First part ran .104 CRS @ 500 IMP on the internals and 1000 IMP on the externals. With the factory settings. We should be able to dial those up and really make it sing...
We need to play with the new Skip Cut Option. Can do Square Perf patterns in seconds...
dutchgray
Dorset. England.
Usually, but not always, it American made double ended metric wrenches that have a hopeless size progression, the Japanese and the European makers have pretty much always made sizes that suit their own markets, since that is what was mostly seen in earlier times, JIS sizes in Japan, DIN in Europe, it may also be why here in the UK there are still so many wrench and socket sets that skip metric sizes you actually need since they are not aiming it at worldwide metric standards.
90zcar
Sweet! That said I actually have a snap on ball peen dead blow on it's way...
They are nice but the estwing feels better. Never did like the fat center plastic on the snap on ball peens. Gets in the way sometimes
nbruno
Had to take advantage of the SK holiday sale. Ordered the 4pc long set and 5pc standard set. I'm not sure why I ordered the standard 5pc set, I guess more curiosity than anything. But I gave them a test run replacing the oil filter housing/ oil cooler/oil pressure sensor/ coolant temp sensor/ manifold gaskets yesterday.
Moral of the story... I like my hard handle Snap-ons better.
Also ordered a power probe this afternoon.
dodge610
North Canton Ohio
ea19565048043fa8c3399e87d8d89b35.jpg5269c313bb3786dbc40476f3e6a4e9b0.jpg6f8a7a0a6bd3f055c6e0025058c9343b.jpgA few new toys to add to the arsenal.
ca90ss
California
Tonyuk
Scotland
I can see where your coming from, i've been counter-holding the opposite end with a long pattern combo but a set with a few multiplies would be very useful, cant seem to get them here unfortunately.
Picked up a few things in the Christmas sales;
New set of milwaukee small needle nose locking pliers for crimping lines off. Also picked up some grip-on pliers to see what all the fuss was about. They're nice but i would never pay the snap-on price for them.
Pair of knipex auto wire strippers, nice for the £15 cost and made in Germany, strips from 0.2 - 6 wires so good for most things.
Also picked up a big pair of 16" channellocks, good for dealing with seized brake pistons when the smaller re-wind tool just wont cut it. If it takes more than this set of pliers to get the piston moving the caliper will be junk more than likely.
Finky198
North East
A few things from the past few weeks...
A Snap on CJ84B off eBay.
some bondhus stubbies and Lisle tap sockets.
OCD
Edmonton, Ab. Canada
Got some free T shirts, and picked up the new ctr767gwb long neck 14.4 ratchet...
It also came with a battery, that's where the serious problem arises, wth is this???? :dunno: :confused: :sad:
