Looking for a STRONG adhesive.
Rick B.
East Tampa
What would be a super adhesive that could be used to bond rubber to metal? It would be used in a situation where the rubber is being used as protection from vibration and I would prefer that the rubber not separate from the metal. Any ideas?
Mustang1167
Pittsburgh, PA
E6000 adhesive. I’ve had great luck with it. The company should advertise it better. I looked at the description on the company webpage and it mentions being vibration resistant.
malibu101
Walnutport PA
Agreed.
If you like E6000 when the need arises try UV6800. The 6800 is UV resistant and clear instead of black.
Both are good stuff. I always have some on hand. :thumbup:
6768rogues
Western NY
I had some 3M industrial adhesive that is used to glue rubber boots to airplane propellers. It really holds. If you know anyone in the aviation repair business, it is about $40 per quart. I don't know where else to get it.
matt01073
western mass
3M 5200 was mentioned above it is a great product , if you go that way be aware there is white and black the white is what you want as the black one is slow dry Theye do mean SOOOOOOOW when they say it like 4 or 5 days slow, the white is normal dries and wors very much like 3m window weld whitch is windshield urethane . 3Malso makes a 2 part structural adhesive that will glue anything together dont have a p/n but a small red box with 2 tubs and called strucural adhesive. all 3 will work great the window weld is in a calking gun tube and once you open it your done so use it and dont expect to use that tube again later, the 5200 stores ok for a while its in a tooth paste type tube and is a marine product that will set under water. the structural adhesive stores well as long as you clean the top of the tube or else the caps seem to bond to the tube .
Daniel Dudley
Permanent bonding – above and below the waterline
Industry standard for over 50 years
Offers extended working time
Achieves handling strength in 48 hours
Tough and flexible polyurethane polymer forms strong bonds
Capable of retaining strong bonds during vibration, swelling, shrinking or shock
3M™ Marine Adhesive Sealant 5200 is a one-component, high-strength, moisture-curing, gap-filling polyurethane for permanent bonding of wood, gelcoat and fiberglass. It cures to form a firm, rubbery, waterproof seal on joints and boat hardware, above and below the waterline. This product has been trusted throughout the marine industry for over 50 years.
LS6 Tommy
Northern NJ
3M Scotch Weld 1357. I must have made 5 trillion door sweeps at the pharma company. Nothing better than a thin coat of contact adhesive for rubber to metal.
Tommy
Platonic Solid
CT-USA
There are so many adhesives out there to suit various applications that defining one based on the vague description isn't realistic. You can contact the manufacturers* with your specific requirement.
*Henkel (aka: Loctite), 3m, Dow Corning, JB Weld, Permatex, Bostik, Sika
Kpaige
Big Lake Minnesota
Black rubber roof cement comonly called black glue at a roofing company. That is what it is used for. It is a high grade contact cement
Lelandwelds
Central Texas
Tommy
This stuff is good. You let it partially dry and then stick it together. Depends on exact rubber type what works and doesnt. Chemistry (adhesives) has lots of rules, exceptions, and details.
visiting guest
clean metal really good first.
use red guard rolled on to metal.
let dry.
then use 3m adhesive rolled on .
the same 3m adhesive used for landau roofs of cars and Formica to counter top bonding put 3m glue on both metal and your other piece
and let the 3m cure to point where instruction say they can be bonded.
dry to touch
then use dowel rods and stick down starting from middle and work outward rolling from center to edges with roller.
rburke65
Canfield, Ohio
Rubber to metal? Weather stripping mastic....the kind used for automotive work. And I have used the E6000....purchased at JoAnns Etc. and it woks well.
6PTsocket
E6000 is also sold as GOOP in many variations. They should all work. I saw E6000 in Wally World the other day
doublearon98
Hamton, Arkansas
JB-Weld Epoxy
Either of theseeddbd997555bd2820479959abd832265.jpg256859b718c375030e747de28c9fbd79.jpg
R
Rick B.
East Tampa
Thanks for all the responses. I'm sure at least one if not all will do the job.
BTW. Here's what I have to bond. A floorboard bumper on my Heritage Classic.The bottom piece that pulls through the lower plate so I'm going to try and bond what's lefty to the plate. Beats spending $139.00 for a whole new plate set.
View media item 78609
kbs2244
Go to NAPA and get the stuff they use to hold roof racks to SUVs.
theoldwizard1
SE MI
3M 5200 is pretty stout stuff
A recent online, not perfectly scientific test, showed that 5200 had the highest strength and still some flexibility of any of the common adhesives.
It is expensive.
It take a number of days to cure fully.
Like everything else being bonded, it must have some "tooth" to both items and it must be clean.
