Lock ring pliers needed asap
thejudges69
youngstown, ohio
I need a set of lock ring pliers. I'm trying to install a lock ring on an output shaft and the set I have are snap on srp5a and thry won't spread the rings far enough. I have snap ring pliers but there is no holes to insert the tool. Any suggestions? I gotta get them tomorrow, so hopefully I can locate them.225f4660db135fb05ac41de8099ce894.jpg4021d6afb7ab2259d940a491dcd0df8a.jpge60e1de1644de5ba69fd377a37237a42.jpg
Sent from my XT1650 using Tapatalk
601HP
Matco P24 A. Not cheap, but is a must have for this type snap ring.
GALLERY]
GALLERY]
WittHay
Surrey, BC Canada
A standard lock ring/snap ring plier like the Snap-on SRP2B should work, the jaws open wider than the compound parallel jaw pliers
The Matco P24A is similar to a Mac TP602R, they are called a reverse bevel snap ring plier and I use them on the type of ring shown in the picture. Different than what you are working on
T
thejudges69
youngstown, ohio
I don't have a matco dealer close. I do have a couple tool places so I'll see what they offer that's like those.
WittHay
Surrey, BC Canada
The Snap-on SRP2B as shown in the picture is your standard lock ring plier. A similar version is sold by a lot of tool companies.
Ole Slewfoot
Freedom, CA
How big does it need to open? I can't really ttell the scale in that pic.
I got blue point pliers to barely work on my NV271 output shaft(maybe 2 1/4"?)where my Craftsman and a few others wouldn't.
T
thejudges69
youngstown, ohio
I found these on matco's website. I just have to find a dealer.
://www.matcotools.com/catalog/product/TP49R/LOCK-RING-PLIER/
T
thejudges69
youngstown, ohio
If you're in a pinch - maybe 2 flathead screwdrivers with a wedge between the tips..
I tried this method and there just isn't that kind of room. I made a lot of new cuss words trying this way. I also tried getting the screwdrivers into the gear and roll the ring out, I was able to get the old ring off that way, getting the new one on isn't cooperating that way.
T
thejudges69
youngstown, ohio
I don't have that measurement. I can later this morning after I get the house moving.
601HP
I don't believe you'll be satisfied with that style. I purchased a very similar product while rebuilding a Ford Toploader transmission. Use of it proved to be frustrating while attempting to install approximately 3 snap rings of your type. I finally bought this and I was able to finish the transmission rebuild. The Matco P 24A was the 3rd set of pliers I bought while working on the Toploader. It fits best because as you spread the jaws of the pliers, the contact face (angle) of the jaws match the angle of the snap ring.
I bought it from a Matco salesman's warehouse on wheels (bread truck style vehicle!)
https://www.matcotools.com/catalog/product/P24A/SNAP-RING-PLIERS/
T
thejudges69
youngstown, ohio
These will work. I can't find a tool truck or dealer though, I got a couple options. I need these today, so I gotta take what I can get.
T
thejudges69
youngstown, ohio
So found these. I called several places and this was my best option. They open to right at 2" . S&K 7636.
jubilee
Colorado
I have made several sets of snap ring pliers for different applications. Buy cheap needle nose vice grips and grind jaw points to fit ring. Quick and easy.
Kaane
The SK ones are just rebadged wilde ones. Hope you didn't overpay.
T
thejudges69
youngstown, ohio
They have a couple tool trucks and a retail store. They sell sunex, sk, gearwrench, Lang, champion cutters, lots of stuff. Some of the prices could use some adjusting. But in a pinch they've come through for me.
md21722
Mt Juliet, TN
Craftsman sells a pair for about $15-19 but I prefer the Snap On SRP2B that cost around $54. They're more stout.
