Swingpress
- Joined
- Mar 16, 2017
- Messages
- 537
SHIFT I had another 107 that needs more work than the one I just got so I swapped the main screw nut for now. There are some very good machinists at my work so I’m going to pick their brain and see what we can come up with.
DRIVES thanks I will check that post out!
Merry Christmas everyone!
....On another note, Small Daughter brought a young man home from school to visit for Christmas. And he sure enough left something hard and heavy under the tree for me. 4-1/2" Columbian. Pics below. What a nice young man...![]()
And maybe half a dozen Bugattis like this one?
Seriously, do any of you guys have one?
Nice one CA !
Is that a 406 perhaps?
FW:
Great job! I love that Corrosion X finish you applied. You polished the tops of the letters, right?
Had the day off yesterday and was fishing through the local for sale ads. I found this big son-a-***** Prentiss No95 and ended up buying it this morning. Seller said it was his grandpa's who lived in the New Jersey area and worked on ship related items. There is number 18 stamped on the bottom of the dynamic jaw...what does this mean? I am going to ask him to text me the history of the vise so I can share with others. Unfortunatly it has been sitting on his garage floor for the last 20 years, so there will more then likely be some issues to deal with.
The swivel base appears to be fused via rust to the base. I was able to get the swivel lever to turn w/o much force, so we will see what happens after some heat and vinegar. Based on the condition of the lever, someone was trying pretty hard to get it to clamp tight.
I have the dynamic portion soaking in a vinegar bath right now, and will put the static portion in later. How long do you think she should soak?
Jon
Maui, Shiftless and I have responded to your enquiry on the vise repair thread where you had posed the same question.
https://www.garagejournal.com/forum/showthread.php?t=252830&page=269
007
. I can believe that!I saw that...thanks!! I'm excited to own my first nice vise. What I'm not so thrilled about is hauling this pig around!! Vise Spreadsheet says its 115lbs. I can believe that!
JoeHappy New Year All! Went shopping Yesterday with the bride and brought these home, quite the eclectic grouping...
1.) Parker 439 in really clean original shape
2.) Columbian 5" with pipe jaws
3.) 2" Prentiss swivel jaw
4.) 3" early Wilton #3 with some oroginal label left. Slide is dated 09 46
5.) 3.5" Athol Swivel
6.) 2 odd design machinist vises with cam lock
I picked up an old Wilton 500 bullet today and it had Chicago 14 U.S.A. Does anyone know what the 14 represents? Thank you in advance.
Jon
In general the feeling among GJ members seems to be that the bigger the vise the better but there is something to be said about reasonably sized vise say around 50-90 lb and 4” -5” jaws which should suffice for most average needs of a home garage. The needs of pros and serious collectors are of course different.
Most likely someone would happily trade a smaller vise for your 115 lb vise should you be interested
007
Jon
how many englishmen does it take to use an 8" vise?
None ;they don't have any...
Thru: 14 for Chicago used to be their ZIP CODE
Honza: i wouldn't have asked cause other than needing a good stripping that Athol looks pretty decent and is worth a lot more than that.
CA: KEEPER??
Quality over quantity.
It's not the size of the wand which matters, but rather the magic of the magician.
On a slightly related tangent, finally decided what & how I'm going to mount to the new bench. Swindens 4" & Parkinson 3". Going to chop that piece of butchers block underneath them in half, and have the vices bolted to their blocks and then bolt the block to the bench, so that I can switch between them if desired. The Parkinson will likely be the main resident.
To me stationary vises are meant to be mounted on a stand with 360 degrees of access around the vise, whereas swivel vises are meant for a work bench where access is limited. But I am sure you could find use for it.
Another thing which we tend to differ from you lot over there on.Who needs swivellers.
I am unclear as to why one would choose a stationary vise when a swivel is available?![]()
