gas storage
clawman
Would a Jobox or similar be a good storage container for gasoline cans? Would fume buildup be a safety concern?
1/2 Cup
Member Emeritus
Shepparton. Victoria. Australia
clawman, I am not sure about a Jobox.:headscrat
Can I suggest you ask the question of Jobox
I would investigate the gasoline MSDS and local health and safety procedures / standards and go by those recommendations.
Whatever storage you elect to go with it will need to be very well ventilated as fuel storage does pose a huge risk..
DARK AGE 53
Not a JobBox but I have a metal cabinet I keep my fuel tanks in, on one side near the top it has a 2" hole with a piece expanded steel weld over the hole.
850xpeps
I store mine on an open shelf either in the garage or in the storage shed
gmwelder86
Oakdale , ca
They make cabinets specifically for storing flammable materials in. Typically yellow with self closing doors and ventilation.
kd3pc
Northern Neck
Fairly pricey...and may aggravate your home owners insurance, if you tell them. They do work though. Each shop at school had at least two or three. TN and VA have regs as to what can be "mixed" storage and what has to have only "xxxxx".
C
clawman
matt_i
SE Michigan
As suggested I would cut an inlet bottom and outlet top to avoid concentrating vapors. I would not expose it to direct sunlight either. Keep temp swings to a minimum.
I would think typically the individual fuel containers are good enough to hold their own contents. The metal shell helps avoid any damage and helps if fire potentially started inside or out of the metal shell.
rburke65
Canfield, Ohio
All mine are in the pole barn sitting on the floor. Got to free up the floor space....need to get rid of some stuff. Too cold right now in Ohio.
bob15
Northeasten, CT
What is wrong with a shelf?
Or look at one of these (can be found cheap enough used on C-list): https://www.uline.com/Product/Detail/H-1564M-Y/Safety-Storage/Standard-Flammable-Storage-Cabinet-45-Gallon-Manual-Doors-Yellow?pricode=WA9236&gadtype=pla&id=H-1564M-Y&gclid=EAIaIQobChMIz5Lf1orE2AIVFbjACh38EQVpEAQYAyABEgLqO_D_BwE&gclsrc=aw.ds
Jlbc212
Northeast MA
I store gasoline in the pictured safety cans and in equipment and vehicle gasoline tanks, most of which are in the garage.
gearhead1
NC
This is the best way I think. I found 2 on govliquidations.com and won the auction for $50. I am close to a military base that has a DLA (formerly DRMO), so it may be an option if you’re close to a government facility listed on the website.
EOC_Jason
Bentonville, AR
Where are you wanting to store the gasoline cans? In your garage? Outside? Somewhere else?
How many cans / gallons are we talking about?
What are your main concerns? Fumes? Keeping away from kids? Leaks?
LS6 Tommy
Northern NJ
they do come with plugs but they are made to be vented outdoors'
You may vent them to the outside but there is no requirement for it. It's preferred to leave the plugs in. The point of a flammable/combustible storage cabinet is to minimalize the content's to exposure to a fire outside of the cabinet, not reduce the risk of one inside the cabinet.
Tommy
ezover
3rd rock from the sun
I found a plastic shipping container with a open top. made a over sized lid for venting and it sits out side my barn. it will hold 8, 5 gallon cans.
if I remember right it was a plastic tote bin from Chrysler. I will try to remember to take a picture next time I am out there.
kbs2244
Most Job Boxes I have seen have "leaked" enough air wise that I wouldn't worry about fume build up as long as you keep it out of the sun
If it is out doors, paint it white and shade it somehow,.
BTW, I an sure that, because of product liability concerns, Job Box would say "No way."
