I'm sure this has been covered somewhere here in GJ already, but since I'm fairly new I'll start this again:
I recently replace front and rear shocks/struts on both my '04 Jeep Rubicon and my wife's '11 Kia Sorento.
I ended up breaking one of the rear upper shock retaining bolts on my jeep and spent the following two days grinding out the rest of the rust-welded bolt with a Dremel and about $60 worth of grinding stones. I didn't want to do anything more aggressive heat/spark-wise because the fuel tank was only about 6" away. On the Sorento, I had to grind both of the rear shocks away from the knuckle - and very carefully because I didn't want to have to replace the knuckles or spend even more time trying to press a damaged bolt out.
Here is my question: Would an anti-seize compound have been recommended when I installed the new shocks or is this not recommended on suspension parts? On the contrary, when is it appropriate to use Loctite - if ever?
