My local IA ( inspection authority) has challenged me to come up with a solution to a problem. I have a neighbor with a M35 (1960) Bonnza and the pliable fiber duct that goes from the back of the air filter assembly to the on which the air intake plenum has deteriorated and must be removed and replaced . It is attached with eight screws (Phillips head) the lower six are not easy but can be removed with patience. The upper two are hidden behind the cross brace for the front engine mount. To make matters there is only about 1 inch of clearance. Additionally the intake plenum adds another restriction. So the question
who has ideas on how to get them out. I need a minimum clearance racket that it can insert a very short Phillips head screw driver bit into. Ideas are most welcome . Thanks
thebulkhead behind that limits clearance is about I inch and the screw is just over 1/4 inch long so I don’t have much room . The bulkhead / bracket prevents using a normal screwdriver and being a structural member I can’t cut a notch in it ... this duct is designed to be replaced with engine removed
