I need a tool and ideas for an aircraft issue
f4 plt
My local IA ( inspection authority) has challenged me to come up with a solution to a problem. I have a neighbor with a M35 (1960) Bonnza and the pliable fiber duct that goes from the back of the air filter assembly to the on which the air intake plenum has deteriorated and must be removed and replaced . It is attached with eight screws (Phillips head) the lower six are not easy but can be removed with patience. The upper two are hidden behind the cross brace for the front engine mount. To make matters there is only about 1 inch of clearance. Additionally the intake plenum adds another restriction. So the question
who has ideas on how to get them out. I need a minimum clearance racket that it can insert a very short Phillips head screw driver bit into. Ideas are most welcome . Thanks
toolman9w
Southern Indiana
https://www.grainger.com/product/3ZH36?cm_mmc=PPC:+Google+PLA&s_kwcid=AL!2966!3!219726178498!!!g!356585828113!&ef_id=WljsewAAAGDlX0sY:20180123001058:s&kwid=productads-adid^219726178498-device^c-plaid^356585828113-sku^3ZH36-adType^PLA
Or similar. I googled bit ratchet
F
f4 plt
Offset screwdriver.
Tried one clearance issues. From the screw he’d when fully seated to :willy_nilthebulkhead behind that limits clearance is about I inch and the screw is just over 1/4 inch long so I don’t have much room . The bulkhead / bracket prevents using a normal screwdriver and being a structural member I can’t cut a notch in it ... this duct is designed to be replaced with engine removed
pepi
Woodstock, GA
Top tool has a ratchet action, the tab to the RH changes the direction. The phillips and common bit is fixed, none removable.
The bottom tool shown above, allows bits of any style to be used. The tool must be flopped to change directions.
Here is the advantage, once the OP removes the fillips, he can replace the phillips with a 1/4 hex head screws, think gear wrench 1/4 in.
Greg
Kenstone1
You need a reversible squeeze ratchet
https://www.amazon.com/dp/B000K1NXGW/?tag=atomicindus08-20
Not available though...
Chapmen makes a set of 1/4" hex bits that come with a small/thin 1/4" hex ratchet.
Because it is turned over to reverse, it can be wedged into a confined space when backing out a screw with no way to reverse it/get it out, ask me how I know :eek:
Chapmen Set:
https://www.amazon.com/dp/B00T34D8GW/?tag=atomicindus08-20
I have a similar one that is reversible but cannot get to it now to find out who makes it.
Here's a thin/reversible 1/4" hex ratchet that might work, I have 3, one straight, 2 offset:
https://www.amazon.com/dp/B0748DCVHN/?tag=atomicindus08-20
Edit: a simple solution would be turn a Philips 1/4" hex bit with a 1/4" ignition wrench, done that before.
M6erfan
'Merica!
https://store.snapon.com/Low-Profile-Screwdrivers--2-PHILLIPS-reg-Tip-P794487.aspx
You'd be hard pressed to get lower profile than that. Yes, I know someone else makes it for Snappy, but $16 delivered to your door isn't too bad.
These are about the lowest profile you'll find. Also, they're rebranded Anex (Japan) so you should be able to find them cheaper than S-O.
Edit: matter of fact...3 for less $ than 1 S-O;
https://www.amazon.com/Anex-6102T-Profile-Driver-Handle/dp/B0016VAIBI/ref=pd_sim_469_1?_encoding=UTF8&pd_rd_i=B0016VAIBI&pd_rd_r=ECCZF0QJT61235XBEP3C&pd_rd_w=jnwpO&pd_rd_wg=FQ5sf&psc=1&refRID=ECCZF0QJT61235XBEP3C
p_mori7
Montreal, QC., Canada
If the pliable duct needs to be replaced, cut it off close to the screws then twist them out from the inside with vise-grips or drill them out ?
Maybe I'm not visualizing the issue properly.
Could the engine mounts be loosened to gain some more clearance ?
Lassen Forge
These are about the lowest profile you'll find. Also, they're rebranded Anex so you should be able to find them cheaper than S-O.
Edit: matter of fact...3 for less than one S-O;
This. I'd ask your A&P guy what he'd (or she'd) do... stuff like this perplexes normal immortals like us, but it's likely he's seen this before.
The one thing you do NOT want to do is fubar your planes certification if you do it wrong... I was (honestly) thinking a Phillips bit and a long (I think it's 1/4") gearwrench for the ratchet action. You might even (depending on your access issues) have to use a heat wrench to add a handle extension, then bend it, to get to where you gotta go...
But there has to be an easier way, and if anyone's seen it, it's the guys and gals who inspect and fix GA aircraft for a living...
(The cool thing is once you get your modified part cerificated and patented, you may have a niche part that can pay for a number of $250 hamburgers!)
22george
SW Ohio
I worked on large aircraft for 30 years. We shortened the phillips screwdriver bit and welded a handle- steel bar- on the side of it. Used it when had clearance issues for years.
