so you are buying all the local cool stuff!
I need to find one of the speed reduction kits for my Atlas 1020.
Not quite all of it. Here's one in Ypsi with the pulley.
https://www.facebook.com/marketplace/item/216611855551254
Need any other parts?
Thanks for the link. I am not on FB, so I only see craigslist stuff.
I ultimately want to upgrade to a floor stand model. Craftsman, walker turner, etc..you know the drill [pun intended]. Keep me in mind if you see a seal that you do not want.
At the moment, I have three floor-standing bases and columns, and a couple appropriate Craftsman motors, for a floor-standing conversion.
The knob that holds the handles is in rough shape. Pitted and peeling. Do I want to knock out the pin that holds it onto the shaft so I can get an and clean it up? I don't want to jeopardize the spring..
I don't 'need' a machine by any means. But who doesn't like an upgrade?
This is mine. It works well, has some wobble but its manageable [any pointers how to correct that? I have tried to persuade the chuck with a mallet and made improvements] Spindle runs almost dead true, it seems to be an issue w/ the chuck and taper.
I may eventually try and make a speed reducer, since I only deal with metal fab I never use anything except current lowest speed.
Thanks Frank.It wouldn't hurt.
There is a pin in the hub that passes through pinion shaft. That pin holds the hub to the shaft and also passes through the loop on the spring. One end of that pin is knurled.
You should be able to see some witness marks on the edge of the hole on the hub from the knurling. You want to identify that end and drive the pin out from the non-knurled end. Otherwise, you'll be driving the knurl through the other end and compressing the knurls even more. It may not hold as well when re-assembling.
Sometimes, the pin is shorter than the diameter of the hub sleeve. When installed from the factory, the knurled end is flush the the hub sleeve and recessed on the non-knurled end. You can normally drive it out from the recessed side.
Also check this post:
https://www.garagejournal.com/forum/showthread.php?p=6347465#post6347465
My brother stopped by today and dropped off a 3450 rpm motor off a table saw he scrapped out. It will work well to replace my grinder so I can use that 1725 rpm motor on my DP press. The date code on the 3450 motor looks like either 8 53 or B53. My 1725 rpm motor is H4 56. Heading over to Harbor Freight so not much getting done on them today.
So lesson there; put some good dissimilar metal anti seize on when reassembling...
]Thanks for the info sir. Like everything else on this DP, the pin came out easily. It was greasy and that kept if from any corrosion. I was also surprised at the condition of the spring. Pretty much greasy and like new. I got the motors switched out on the bench grinder. I had to switch yellow wires so it would run the right direction. It squealed a little when I first started it up. Someday a rebuild project. I took the saw mounting bracket off and see the base of the motor from my brother is cracked if anyone has one for sale. Primered the head unit today and started polishing handles. Glad I could sit down in front of the polisher. Thanks for the guidence FrankLee![/B]
I've been following this thread for a while, looking locally for a DP to pick up. Will use for woodworking. I saw this one nearby, could not get the model. Can you tell what it is? Any opinions on functionality? Thanks
That Atlas is a beauty! Is that original paint?
I recently picked up an Atlas-made CM drill press, and hope it cleans up as nice as yours.
Don't wait too long at that price. If it runs true it's worth every penny.thanks Outlaw and Frank. I have bookmarked that page for future reference. They are asking $125, we'll see how much they'll come down.
The first thing I do for noisy motors is to remove the bearing covers, clean out some of the grease with a cotton swab, and apply a few drops of oil to the bearings. That usually works well to quiet them. I have to do this to the motor from the table saw above.
How badly is the 3450 rpm motor base cracked? Please post a photo.
Here is a picture of the crack in the base. It bolted down even on the bench. Take into consideration what I think is good shape and what my younger brother thinks is good shape are 2 different subjects. At some point I will restore the new grinder after the drill press. Also a couple pictures of the head unit primered. What do I want to get similar to the factory gold/bronze? Is it the Rustoleum "Hammered Bronze"?
Thanks to you guys for leading me down the right path. If I hadn't found this forum, the restoration wouldn't of happened. Bear
Multi-Speed Attachment Installation
Installation is fairly straight-forward following the Installation and Operating Instructions, but here's my procedure:
- Verify that the middle pulley is fully seated in the column. Do not tighten the pulley lock screw yet.
- Place a straight edge on top of the middle pulley. The straight edge should be long enough to span all three pulleys.
- Adjust the head-frame on the column so the spindle pulley lines-up with the straight edge.
- Adjust either the motor on the motor mount, or the pulley on the motor shaft so the motor pulley aligns with the straight edge.
- Install the belts loosely; front belt first, rear second.
On 15½" machines, the 29" belt in the front position and the 27" belt in the rear position.
On 13½" machines, the 27" belt in the front position and the 29" belt in the rear position.- Tighten the belts by adjusting the motor mount. Use a wrench on the flats of the middle pulley shaft to help tighten to front belt.
- Lock in the motor mount
- After a while of drill press use, retighten the belts and then tighten the set-screw on the middle pulley.
10-4 on the 404. Thanks for letting me know.
Here's a good link to the instructions: http://vintagemachinery.org/pubs/222/7313.pdf
Dismantle
- Remove the outer sleeve.
- Loosen the set screw in the base for the bearing shaft.
- Lift the pulley with shaft out of the base.
- Back out the three screws above the bearings only until they clear the bearing's outer race.
- Press the shaft with bearings up through the pulley.
The bearings are tightly pressed onto the shaft. They can be removed with a press. I usually just soak the bearings with shaft in ATF.
There is a hex socket screw in the base on an angle. That is used to tighten the assembly into the column. Do not over tighten and on your model, do not tighten without the large snap rings in place. Otherwise the outer sleeve will crack in two.
The Duralast 15xxx belts I mentioned above were incorrect. Those were 3/8" wide; too narrow and they bottomed-out in the pulleys. Duralast part numbers 17270 and 17290 would work, but I opted for the HF Accu-Link. A little more expensive, but a good choice.
Hi Frank. I have a lead on this DP about 2 hours from me for $30. I sent them a message. The head band looks good and I do need a new spindle pulley. Hope they call me back. Bear
