Show us Your Vintage Bench Grinders!!!!
454ragtop
Carver, MA
Shift, that actually looks like a buffing arbor on a basic cushion mount motor. Nothing really to be afraid of, probably works OK for what it is, though I suspect it's underpowered for a lot of uses. Google dental lathe to see similar manufactured buffers.
Shiftless
East Bay SFO
You're right! It didn't occur to me that when the seller called it a grinder, it was probably used as a buffer... not scary.
Seller says that it was his grandpa's machine and obviously just wants to get rid of it.
edit: If anybody wants pieces of that thing, let me know right away. I just heard from a member of the old guy's family saying it is heading to the dump soon.
I don't want it and I have to resist getting fairly large stuff even free that may or may not be useful in the future.
drivesitfar
Shift: i've got one similar to yours with a hood made out of metal sitting on shelf somewhere.
in fact i like the idea of containing all the stuff flying off a grinder or buffer with that style of hood.
Outlaw: i'll get you and anybody that wants some pictures of my old antique hand grinder as soon as i get caught up around here before the rains start again.
EOC_Jason
Bentonville, AR
bagged89s10
CT
Just picked up this delta with stand for $40. I think it’s a 1/2 HP. Only thing wrong with it is the broken eye shield. Does anyone have an eye shield for sale?
exmaxima1
Midwest
Great score! The stand and cast water cup (the right side cup) fetch far more than your cost--you can toss the grinder out. :thumbup:
flippin
Montreal - Ottawa
Got lucky!! Found this vintage Black & Decker - Van Dorn 8" Heavy Duty model 74 type G about 20 minutes from home. Includes the bench and Square D switch. Only $60 Canadian, about $45 USD. Immaculate condition, runs forever after powering off. Glass is intact, all 4 lights work and the spark arresters are in place. Again I got lucky!!663d6110be76aa9ebc567f9b0255813a.jpgb5d5092a59ed5da82a200922ea66bc20.jpg56ff70e1c0f194bc635144bf9b124267.jpg3a4314e033ead8120bb18590b0c6f3a9.jpge35ccbe0b7a538661fbc65cffc9b791e.jpg01da495864137a1a7bfa7e372e16aaa5.jpg378b2b014029bf3e4afe3b9a8955dbf6.jpg
Sent from my BBB100-1 using Tapatalk
Cahark
Dayton,Oh
Here’s my contribution. Started out as a baldor grinder with a bent shaft and a shattered base casting. I assume it was dropped. I straightened the shaft and repaired the base. I ended up with a nice wire wheel/buffer. Check out my thread on the repair.
(IMG]https://uploads.tapatalk-cdn.com/20180203/002c2098154493310c9c168ebc35ab56.jpg[/IMG]
larryq
Wonderful grinder there, with all the accouterments anyone could want. For $45 USD. You ****.
hitthewall79
So I picked this up today, when I went to buy a bench vise, can someone please tell me more about this bench grinder? 6547d9ce5de9d74a4ddb92899983a51a.jpg08488152496855f457c232435cbf0940.jpg
Sent from my SM-G955U using Tapatalk
Hmm, Lots of questions on that grinder! Why:
  • The Pillow blocks between the wheels and motor housing?
  • two switches? Why?
  • Odd motor guards - Fabricated?
  • Is this an open frame motor?
Forgive my ignorance, but this is my first bench grinder, so...
1. What are the pillow blocks?
2. From what the previous owner told me, one is for the grinder, and one is for the lights that sit above
3. Where are the motor guards?
4. How would I tell if this is an open frame motor or not?
1. Bearing supports
3. thes sheet metal guards?
4. Under the guards is the motor enclosed, or can you see big openings and windings inside? (Common on Washer/dryer motors)
I don't think this is a grinder as sold from hr factory. I think it was fabbed up and probably during WWII when tools were hard to get for the civilians.
I looked from 1935 to 48 in the catalogs. Not in there as pictured...
hitthewall79
1. Bearing supports
Pic 1. Does that help any with bearing supports
Pic 2. Sheet metal guards look like they were made to fit that button, so maybe not?
Pic 3. How would I go about exposing whatever is under the sheet metal guards? 6f44b5a98b3f3a8111bf89b328bf2153.jpg9da4aca62d19c6457825ef102062dadb.jpgcb1ccac5256061c1b7374ca67c452aaf.jpg
hitthewall79
I don't think this is a grinder as soled from hr factory. I think it was fabbed up and probably during WWII when tools were hard to get for the civilians.
So if I wanted it to restore it to original, I would remove the sheet metal guards and housing around the grinder?
Hard to tell until its cleaned up and at least partly taken apart.
The shields might be original to the motor, But again "original" may be a motor not a grinder? :dunno:
bigb56
Tucson, Arizona
I picked up a Baldor for $15, so far fixed the electrical and replaced the bearings. Runs great but missing left side guard cover and the right side guard is cracked pretty bad, going to try and braze it if I can't find one used. GJ won't let me post a WTB till I have 100 posts:sad:
exmaxima1
Midwest
Don't bother with the guards. You have an awesome BUFFER the way it sits.
bigb56
Tucson, Arizona
I thought about that but I am having trouble thinking of how I would need a buffer.....Then I have 5 bench grinders presently...hmmmm
Motorman55
South Jersey
Those guards with their crimped sheet metal look as though they just push on over the motor ends (similar to how your house gutter down spouts slip over one another) once you remove all the parts from their shafts.
Cahark
Dayton,Oh
I have a set of guards, but no side covers. One guard has some cracks around the mounting holes. (This is why I now have a buffer haha) pm me if interested.
EOC_Jason
Bentonville, AR
EOC_Jason
Bentonville, AR
A 3/4HP buffer seems a little excessive unless you are buffing large things. Though if I picked that up for $15 and already had other grinders then heck yeah I would use it for a buffer! :lol:
You could also mount wire wheels on it, assuming you are using a full face shield when operating.
You can watch eBay too, I've seen parts pop up from time to time for various brands of grinders. People are always parting them out so you might get lucky.
hitthewall79
So I've run into a snag... Actually 2 of them.
1. How do I get these bearings off? There's a tiny lip on the end if the rod preventing them from coming off, before I go filing it down, should that lip be there?
2. How do I get this nut off, is there a set screw inside of here? f2ec87e7ab8650ea29c24c8cee3ee424.jpgf1f668da803b1e23e0c31aa321943fa3.jpg
hitthewall79
I'm curious too why they made those end caps, the old craftsman motors had curved ends, I even found one with two switches like yours! But the guy claims it reverse direction? I don't know if he actually tried it or not. Maybe it was to help prevent debris from being sucked into the motor?
http://vintagemachinery.org/photoindex/detail.aspx?id=14208
You are the man! This is my exact grinder!
EOC_Jason
Bentonville, AR
In regards to your first question. Are you saying a 'lip' at the point where the shaft diameter steps down? Was that were one of the washers were? If so it probably just got mushed out over time from pressure and you can file it smooth.
Not sure what you are taking of pic of in #2... Maybe you should clean off that grinder before tearing it apart?
Just leave the bearing on for the time being. You need it apart to clean and identify, so 100% disassembly shouldn't be needed.
hitthewall79
Torn down, and waiting to repair the cord, it was dry rotted, so I'm just replacing jtcd4863b4facfd114ed874e765e1343e2.jpg
Are there any setscrews on the "Nut" portion of the arbor? I'm trying to figure out if the shafts are add on and they felt they needed the extra bearings, or if its all one shaft end to end and the berings are really superfluous?
Hmmm, another possibility: Does the motor have bearings or bushings? Maybe those are to unload the bushings if not bearings inside the motor.
Has the base motor been identified? If not what is its full model no? Maybe a catalog can add info...
dodge610
North Canton Ohio
4b348c9f567174951cd554ae6012753a.jpgDont know if I ever posted this one got it last summer for $10.00 the guy I got it from was an old guy that I used to work with didn’t know it was him till I went to get it.
hitthewall79
Yup, there sure are, a nice set of stripped set screws, not from me btw.
How do I tell if the motor has bearings or bushings, since I can't get inside of it? Yes, thanks to another user, we found out that it was Packard Electric Co. & Packard Electric Division-General Motors Corp., Warren, OH. Manufactured by Sunlight, model # 115.5559
Actually that was me; I just could not read the whole Model number. 115 = Packard. The rest may help ID the motor? I think someone else found a 2 switch motor in the catalogs? but what year?...
To tired to look tonight...
exmaxima1
Midwest
Great buy! Can't tell from the small pic, but it looks like it may have been made by either Baldor or Doerr---both excellent makers. :thumbup:
EOC_Jason
Bentonville, AR
That whole nut w/set-screw and double bearing combo is really crazy...
The single nut doesn't seem wide enough to join two shafts together, usually one sleeves over the other with 1"+ and a couple set screws.
The bearing assembly makes it look like they want any load to be taken there instead of inside the motor, maybe it does just have bushings like you said and they wanted to beef things up?
The whole design of the grinder looks crazy over-built, especially for its HP... Either it's a very early attempt or maybe it was used in some harsh environment? Or maybe some machinist got bored and decided to overbuild one the way he wanted?
hitthewall79
So I may if just screwed up, as far as I knew, white cables is always positive, and black cables are the hot ones. In the outlet, the little hole is hot and the the big hole is positive, right? Put a new plug on, it sounded like it grinded for about 3 seconds, and then I heard a pop, and the button on the side popped out, signaling it was either overloaded or overheated
