What tool do I need?
4 Ever-Fish N
Deep East Texas
The transom plug for my boat has a square head. I would like to have a small T-handle type tool to install and remove it. I think it is about 9/16". Currently I use an adjustable wrench. Any ideas?
yhprum
Brisbane Australia
ItemDisplay.cfm
maybe this is what you're after?
http://www.tooldiscounter.com/ItemD...RG8g2Jn25MjsVDie5ai3jbLSCxlV0TlQaAqQHEALw_wcB
Mr Ratchet
You can always change the plug out for a brass one that is hex shaped. That way you can just use a normal socket or wrench. I did this on the pump for my in laws sprinkling system.
kd3pc
Northern Neck
they make a T-handle attached to the drain plug for most trailer boats...some even have that T tethered to the boat, so it does not get lost...check your local chandlery.
bests
Doug Arthurs
Ontario
My boats all use an expanding plug with a t-handle you can remove without tools. I would see if one of these would fit. No tool needed.
rlitman
Long Island
bests
I've always used this tool-less style.
4 Ever-Fish N
Deep East Texas
It depends on how the boat was designed. Some boats use these 1" rubber expanding plugs but others use a threaded female brass flange that is built into the boat and a male brass plug screws into that. My boat has both, 2 of the rubber plugs for the floor drain and 1 threaded flange for the bilge drain.
Thanks all for the suggestions. I know I can make one or more of them work better than an adjustable wrench.
Lelandwelds
Central Texas
My former boat came with a tee wrench to fit the plug.
Funny, I was really happy to get rid of the thing but sad to see it go.
rmack898
Honu Grove NE Florida
Check out the “Rite Hite” stainless steel prop wrench. It is the only tool I use for boat drain plugs, I’ve been using it for almost 30 years. I can’t post a link to it from this phone but just do a search for it on amazon.
4 Ever-Fish N
Deep East Texas
I like it and plan on adding one to my onboard tool kit. Thanks for the tip.
As far as the brass 9/16 square transom plug, I discovered a 15 or 16mm 12 point socket will work. So I ordered a short 1/4" composite ratchet to use with it and I think that will work just fine. Thanks again all.
4 Ever-Fish N
Deep East Texas
This is what I ended up with. A Tekton 1/4" ratchet and a 16mm socket. I believe it will work out fine. Thanks to all for the suggestions.
