Tips on turning a thin wall bushing
01-7700
Maine USA
I need to turn a bushing 1" long with a 5/8" ID and 0.043" wall thickness in aluminum. My lathe is a Grizzly 7x14. I anticipate this is going to be a challenge so what kind of issues will I run into? Any tips?
bigguns69
Iowa
Small bites. I would do the bore first, then finish the OD. If you finish the bore first you could support the thin wall by inserting a chunk of solid bar inside the bushing before finishing the OD.
yaidunno
WI
I made a 2" long .030" wall bushing just the other week in a similar diameter from steel. My process was to turn the OD to size, pilot drill the bore, finish drill the bore, and then ream to final size. When trying to made OD passes after the bore is drilled, you run the risk of chatter, in my experience.
Just my .02
01-7700
Maine USA
good ideas thanks
BuffettFan
Central Illinois
Did 2 of them yesterday in 4130 with a .047" wall. .6094 OD, .5156 ID from solid stock.
I roughed the ID to .4375, turned the OD, then finish drilled the ID, chamfered ID and OD, then parted it off.
1.375" OAL.
Not too tough, take your time and you'll get it.
01-7700
Maine USA
Just my .02
Makes sense if you have the proper ream size. Thanks.
01-7700
Maine USA
1.375" OAL.
Thanks. I don't have a lot of experience but I have enough aluminum for a good number of do overs.
matt_i
SE Michigan
Many light cuts, sharp tool (minimum corner radius, but that's typical on a boring bar anyway to reduce tool-pressure), 6 jaw chuck or collet system all come to mind.
bullnerd
Jersey
ID, OD, Part. 0.043" wall isn't bad in aluminum.
That's what I was going to say. Sharp tool like mentioned would help. HSS if your not familiar with carbide.
I don't think your doing it in one pass like the vid.
kazlx
Tustin, CA
How would I make this expanding mandrel? turn a cylinder and slit it?
Bingo. Turn the OD to maybe 0.005 (or less) under your finished ID of your part. Drill and tap and countersink for a countersink screw. Then slit on a bandsaw, or hacksaw or whatever. Slide your part on and tighten the screw. Don't kill it, just enough pressure to get what you need done.
I think Joe Pie has a good vid on these too:
kazlx
Tustin, CA
His videos are awesome. I hope he doesn't change. Super helpful, usually right to the point with actual problem solving type stuff.
01-7700
Maine USA
Thanks so much!
snyder
Baltimore md.
I would start with a 6 inch long peice of stock, drill and bore bar out the id. Turn down the od and cut off to length.
