Small bites. I would do the bore first, then finish the OD. If you finish the bore first you could support the thin wall by inserting a chunk of solid bar inside the bushing before finishing the OD.
Internal expanding collet if turning OD, boring bar and chuck or collet for ID. Is this the answer you're looking for?
I made a 2" long .030" wall bushing just the other week in a similar diameter from steel. My process was to turn the OD to size, pilot drill the bore, finish drill the bore, and then ream to final size. When trying to made OD passes after the bore is drilled, you run the risk of chatter, in my experience.
Just my .02
Did 2 of them yesterday in 4130 with a .047" wall. .6094 OD, .5156 ID from solid stock.
I roughed the ID to .4375, turned the OD, then finish drilled the ID, chamfered ID and OD, then parted it off.
1.375" OAL.
Not too tough, take your time and you'll get it.
What do you use an aluminum bushing for?
ID, OD, Part. 0.043" wall isn't bad in aluminum.
That's what I was going to say. Sharp tool like mentioned would help. HSS if your not familiar with carbide.
I don't think your doing it in one pass like the vid.
For 1" part can easily make an expanding mandrel as well.
How would I make this expanding mandrel? turn a cylinder and slit it?
Bingo. Turn the OD to maybe 0.005 (or less) under your finished ID of your part. Drill and tap and countersink for a countersink screw. Then slit on a bandsaw, or hacksaw or whatever. Slide your part on and tighten the screw. Don't kill it, just enough pressure to get what you need done.
I think Joe Pie has a good vid on these too:
