What is it? Buss Fuse in socket.
geojag
Little Rock, AR
I have been looking at houses recently, and in a couple houses I have seen a single socket with a screw in Buss Fuse and what appears to be a capacitor. In both cases the houses were reportedly built in the 1970s and have a regular breaker box as well. A picture is attached. Any help is appreciated!
Sent from my Pixel XL using Tapatalk
ABSTIFFGS
Twin Cities, MN
That to me looks like a doorbell transformer. Could they have used the light bulb base as a "fuse holder" to protect the transformer?
Bert_
NW Iowa
I would assume it's additional protection for the doorbell or HVAC transformer that is visible on the side of the box.
A porcelain lamp holder isn't really the right thing for this but I wouldn't get worried about it either since it's a 3 amp fuse...
Bert_
NW Iowa
It's not uncommon to use small fuses like this to provide additional protection to small loads since 15a is pretty much the smallest common breaker.
Most doorbell transformers have an internal fuse but this one may not, thus the plug fuse.
G
geojag
Little Rock, AR
Thanks for the answers. I had initially thought it was doorbell related, but the location and the fuse threw me. I guess the just put it in closets to make them accessible but out if sight.
alfredeneuman
Fullerton, CA
It's a Code violation then
NEC 240.24
(D) Not in Vicinity of Easily Ignitible Material. Overcurrent devices shall not be located in the vicinity of easily ignitible material, such as in clothes closets.
Bert_
NW Iowa
NEC 240.24
Nobody said it was a clothes closet...
Norcal
I don't think it really matters what type of closet, what does matter is closets are used for storage & likely contain material that is easily ignitable.
alfredeneuman
Fullerton, CA
If the wall has wood framing, it's also a violation of this one.
(A) Not over 112-1⁄2 kVA. Dry-type transformers installed indoors and rated 112-1⁄2 kVA or less shall have a separation of at least 300 mm (12 in.) from combustible material unless separated from the combustible material by fireresistant, heat-insulated barrier.
Bert_
NW Iowa
You got a code section for that? I wouldn't mind reading the whole article.
