School Me,,, Whats the difference between a 6 pt.
theo2
Whats the difference between a 6 pt. socket and a 12 pt?
The Cobbler
6 points!
And 6 points is usually considered better for rusted /worn/difficult fasteners as it has more area to grip than a 12 point. 12 point often rounds off on a rusted hes where as 6 point has more meat to grip.
Parrothead
Earth
Search. You’ve got over 700 posts and are asking this? 6 points is the difference. Good luck!
CR888
Using a fine tooth ratchet I don't mind using 6pt sockets but when using a breaker bar I prefer the 11 or 12 point sockets as you can fit them on the fastener in more positions. Plenty of info about this has been discussed, use a Google search if the in house search engine is of no use.
bczygan
DETROIT! Arsenal of Scrappers
Bill
gahrajmahal
Cincinnati, Ohio
More surface area on a six point. Use it for breaking a tight fastener. 12 point use to finish loosening in close quarters. Requires half the swing angle.
In The Doghouse
South of Due West, West of NinetySix in SC
11 point sockets?? Must be for 5.5 sided fasteners.
zorrox
12 points can be used on square, 6 point and of course 12 point fasteners. They are also easier to get a breaker bar on if space is limited. They can however round a 6 point especially on smaller fasteners. It's best to use both 12 and 6 point sockets on corresponding fasteners heads.
That's about it.
BDT/NWMN
Erskine, Mn
The six point sockets are useless when working on equipment with twelve point bolt heads and nuts.
Twelve point sockets can be used on hex head bolts and nuts, as well as the twelve point mentioned above.
Six point sockets are preferred for rusted, worn, or rounded fasteners.
Twelve point sockets allow You to re-position a breaker bar every 30 degrees when turning a fastener; without re-positioning the socket on the the breaker bar.
Twelve point sockets drive some Garage Journal Members into a fit of rage when they are mentioned. Some of Us have both because they are needed. There are screwball tool companies that produce both six and twelve point sockets in an attempt to keep both sides happy.
BDT/NWMN
Erskine, Mn
That's about it.
Yep, there are times that a twelve point socket will slip onto a square plug.. Not that the angle of the socket points properly line up with the four points on the square plug.. It would be interesting to take a poll to see how many of US are guilty of doing this?? I have some square and eight point sockets that are better suited for plugs, but for some unknown reason, there are times I lack the proper size square or eight point socket and ??? :lol_hitti
Jim c
Some main crankshaft bearing cap nuts are actually 12 pt nuts. Some driveshaft universal joint attaching c- clamps are fastened sing 12 point nuts. For these applications you will need to use a 12 point socket or box wrench end. If you attempt to remove these with your 6 point sockets by hammering them on, you will trash both your sockets and your main bearing cap nuts. If you attempt to use 6 point sockets with a breaker bar, you will have to walk half way around your project just to reposition your wrench. If you attempt to use 12 point sockets with a breaker bar, either you didn’t need to be using a breaker bar in the first place, or you will most likely round off the itty bitty tips of your nut. In either case, you should go get an impact wrench and 6 pt impact socket and loosen it the right way. And leave your chrome plated hand tools in that drawer where they never get used anyways. Maybe put them in your trunk tool box , where they might some day actually be useful. As for using 12 point sockets on square bolts: this can be accomplished using a large hammer to mash the 12 pt socket down on to the square nut, and it is a one way ticket only. They actually make a thing called an 8 point socket for square nuts. There also is a square socket for square nuts ( the difference between 8pt and square sockets is kind of the same as the difference between 12 pt. Sockets and 6 pt. Sockets). They also make crescent wrenches for square nuts and, you can use open end wrenches too.
M6erfan
'Merica!
Wait...Is this thread serious?
Cant wait for the "Whats the difference between a phillips and slotted screwdriver?" thread
ocloc24
I hope this is a joke.. a member for that many years and you don't know the difference AND you couldn't take 3 sec and type this into Google?
archirelic
texas
This is about the general direction the forum has been going the past several years. Endless repetitive threads on easily searched for topics.
6PTsocket
My Slobovian lawn tractor uses 11 point fasteners. The SnapOn guy was very rude when I tried to warranty a broken socket. It was a common size, too, 6.835mm.
6PTsocket
What about reed and prince? Looks similar to Phillips head.
But has a sharper point and different geometry. I remember being told Reed and Prince = real pointy
BDT/NWMN
Erskine, Mn
+1 to that
This thread MUST be a joke
OK, if You insist :lol:
Laughter is Good Medicine, and no prescription is needed. Garage Journal is a fun place to hang out, joke around, ask questions, offer and receive advice, learn about new and ancient tools and practices, and overhaul the world in general..
I was once active on the Busiest Toy Train forum on the www. Sadly; various members were entombed in their sober, snobbish ways. One rude member once told me to "go lay down by your dish or something". The rudeness, criticism, and stone faced personalities of some members caused other participants to withdraw membership, and eventually got the Forum shut down for a cool off period. To Me; this shut down came as no shock. Although I haven't signed in for years; I will browse over the threads on occasion. They have some dedicated members whose contributions are highly valued. But sadly, due to certain members; that forum is a ghost of what it once was.
I will take the jokes and laughter any day
